Clever minds think alike. I turned a similar alignment tool out of Delrin on my lathe to help me align the motors mounts before epoxying them into place.
Slow build - 8S Twin Cat
Before epoxying in the motor mounts, I made sure that the two drive tube were the exact same length.
I also epoxied in the drive tube alinement holder.
Seeing that I could only put epoxy on the front side on the first go, then let set up for 24 hours.
Second mount same thing front side - 24 hours
Then I could stand the boat on the tips and do the back side of both mounts, and the drive tube alinement holders - 24 hours
I use West Systems 105 Epoxy, and 206 Slow Hardener, with Fumed Silica
LarryAttached FilesPast NAMBA- P Mono -1 Mile Race Record holder
Here is what my power system looks like.
Tp- 5670 - 1180KV - 6D
I also drilled and taped new holes for the water inputs on the motor coolers,
so the exit would still be at the top of the cooler.
You will also notice that the coolers are now Left and Right.
The original holes were plugged with stainless 6mm screws and Loctite.
LarryAttached FilesLast edited by TRUCKPULL; 12-28-2021, 04:08 PM.Past NAMBA- P Mono -1 Mile Race Record holder
I forgot to mention,
When I did the Carbon Fiber Inlay,
I also added 2mm Carbon Fiber plate to the inside of the transom.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
The second bedroom is my Computer and workshop here in the Condo.Originally posted by ray schrauwen View PostLooks good Larry. Do you do al that at the condo or somewhere else?
There is also a workshop downstairs on the main floor, with an exhaust fan that I use for grinding, sanding, and painting.
My lath, Mill, band saw. drill press, pedestal grinder, ETC are set up at my son's house.
LarryLast edited by TRUCKPULL; 12-29-2021, 03:04 PM.Past NAMBA- P Mono -1 Mile Race Record holder
NICE!
I'm building a baby twin compared to that monster. 28" Pathfinder. Barely started but it's cleaned out ready for Carbon Kevlar... Unless you have some leftover CF cloth you might sell me again?
Looking for a piece about 15" x 22" or longer.
Cheers!
I installed the motors using the Three 4mm screws in the front of the motors,
so I could align the base for the tail ring mounts, and epoxy them into place.
After they dried. I removed the motors to put more epoxy on the front side.
Right now this is my proposed layout.
I am in waiting for an order from OSE for my Carbon ESC mounts and battery trays.
Gonna be a great boat Larry! Happy holidays to you.
Ray your making me miss my Geico twinOriginally posted by ray schrauwen View PostNICE!
Cheers!
Hello AlainOriginally posted by Alfa Spirit View PostThis is an OFNI, 2 x 56106 in a 1,06m. cat
I am not sure what OFNI is,
But yes 2 X 56106 TP motors, 1,066m Cat, 8S- 6000 mAh per motor.
This is for racing in IMPBA S+T or Open Cat, or Open Hydro classes.
LarryLast edited by TRUCKPULL; 10-31-2023, 02:10 PM.Past NAMBA- P Mono -1 Mile Race Record holder
