Zippkits jae 21fe v2 outrigger_wood kit build
  • sammyha
    • Jul 2018
    • 1038
    #181
    Originally posted by Bande1 View Post
    thanks. what ever happened to the 4070?
    The original TP 4070 was 1650kv. That's now in my RSX380, running on 8s, SAW runs only, lol...
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1038
      #182
      Here's a new personal best SAW run for me with the 33...
      • racerr73
        • 133
        #183
        Sam,
        Any chance you will go back to your best 6s pass set ups with either Neu 2050 or TP 2100 and compare speeds with the esc you used then to now with the hydra x8s, be interesting if the hydra is making a difference.
        Trev
        • sammyha
          • Jul 2018
          • 1038
          #184
          Originally posted by racerr73 View Post
          Sam,
          Trev
          Ooh, great question! Be easy to do with the Neu motor, just pop the 6s lipos back in. I'll have get around to it. Takes a little time, waiting on the weather...
          • sammyha
            • Jul 2018
            • 1038
            #185
            Getting some respectable speeds now running on 8s with the 33...
            • larryrose11
              • Jun 2010
              • 763
              #186
              Just saw your 114 MPH saw run video:
              you used a tp 4050 2580 KV, on 6S (57K RPM)
              what prop?
              On the prior SAW run, you used a Neu 1515 40x70mm 2050kv 2D motor on 8s. (60K RPM)
              ABC 1921-19-38(2) CLL prop
              111 mph
              What prompted the motor swap / system voltage drop from 8s to 6S
              • NeverEnuff
                • Jul 2011
                • 19
                #187
                Just curious if you have read the ESC to see what kind of current that setup is pulling and what the ripple voltage is? My JAE was around 190 amps at about 92 mph with a Castle 1515. I know it has a lot more in it, just haven't had the time to play with it.
                • sammyha
                  • Jul 2018
                  • 1038
                  #188
                  what prop?
                  On the prior SAW run, you used a Neu 1515 4070mm 2050kv 2D motor on 8s. (60K RPM)
                  111 mph
                  Both the 111 & 114 mph passes were the ABC 1921-19-38 prop. I swapped motors because the TP Power 4050 SVM series 2580kv motor is the replacement motor I bought after my TP 4050 2310kv motor failed. I'm testing it for another JAE 33FE I'll build this winter...
                  • Bande1
                    • Mar 2023
                    • 678
                    #189
                    look what kind of trouble you got me into, Sam.
                    • sammyha
                      • Jul 2018
                      • 1038
                      #190
                      [ATTACH=CONFIG]177842[/ATTACH]
                      Lol! I'll bet it didn't take much convincing. Zippkits riggers all run so great. Good luck with her...
                      • sammyha
                        • Jul 2018
                        • 1038
                        #191
                        Sorry, no. I've never used data logging. By the temps it comes in at, I would guess it handles it fine. Off camera tuning the boat I've done as many as six passes and temps were slightly warmer. None over 113 degrees. Drained a 5300 mAh lipo down to 3.84 volts per cell...
                        • sammyha
                          • Jul 2018
                          • 1038
                          #192
                          I got around to checking the Data Log. Here's some numbers and I have some questions.
                          These are all max numbers...
                          -209 amps
                          -7,705 watts (edited)
                          -57,674 rpm's
                          They're all pretty extreme, right? Will my electronics hold up?
                          Specs on my electronics-
                          - TP Power SVM series 4050 2580kv motor
                          - Castle Hydra X 8s ESC
                          - Pair of SCM HCL/HV 4s lipos/ 8s in series
                          I keep a close watch on temps and volts...
                          - ESC 104 F
                          - Motor 118 F
                          - Lipos 100 F
                          - Connectors 99 F
                          All fairly cool temps for the application. Is this any indication that it will hold up? This was after three SAW runs...
                          All you serious (aka sick, lol!) SAW run guys feel free to chime in!
                          Oh, btw all this data is from my latest 119 mph SAW run with the JAE 33FE. I'll share the link below...
                          • sammyha
                            • Jul 2018
                            • 1038
                            #193
                            Here's the link to my latest success with the JAE 33FE!
                            • Bande1
                              • Mar 2023
                              • 678
                              #194
                              -209 amps
                              -7,709 watts
                              -57,674 rpm's
                              7709 / 209 = 36.88v
                              thats not right. 10s?
                              • sammyha
                                • Jul 2018
                                • 1038
                                #195
                                7709 / 209 = 36.88v
                                Oops, 7705
