Zippkits jae 21fe v2 outrigger_wood kit build
  • RaceMechaniX
    • 2825
    #271
    Originally posted by EddieM41 View Post
    Tyler, I love all your expert information!!! I can't imagine running a TP 2310 on 6S for more than a few seconds without burning down the motor or esc. Way to many RPM's. I'm running the same motor/hull on 4S and it is fast and can run many laps on an oval. All this based on my personal experience. Keep up the excellent feedback!
    Eddie
    It's definitely on the hot side, but would work for a 2-lap setup. You could run a very small prop for heat racing but efficiency usually drops off too much with the prop and it will tend to blow the tail in a turn. Some boats will run a great with a small prop buzzing to the moon.
    Tyler Garrard
    NAMBA 639/IMPBA 20525
    T-Hydro @ 142.94mph former WR
    • sammyha
      • Jul 2018
      • 1038
      #272
      Deleted...
      Sent from my SM-G950U1 using Tapatalk
      • sammyha
        • Jul 2018
        • 1038
        #273
        First I asked a lot of questions to guys who knew about SAW riggers and then started working my way up from 100 to eventually 148mph. I have probably built around 14 SAW riggers between gas, nitro and electric. Each new boat is some small improvement on the last. When I broke Joerg's 10 year record at 140mph I was only Rev 3 of my own design. Today I am on Rev 9 and only increased from 142 to 148, but it's dead steady on the water and reliable. I have not burnt up a controller, nor cooked a motor, nor waded up a driveline in the current boat. I just have run out of room at Huntsville to run faster. And it also took a lot more than 300A to to get there. I tend to run big boats, but we have run 140mph on a 30" rigger with much less power.
        That's very interesting to me, you chasing speed like that. Just based on the time I put in this summer, much respect. What speed is possible from 300 amps?
        • sammyha
          • Jul 2018
          • 1038
          #274
          Also, my 33 weighs 6 pounds, 13 ounces all up weight with 6s lipo right now. It weighs 7 pounds setup for 8s...
          • sammyha
            • Jul 2018
            • 1038
            #275
            I got a rare chance (here in the north country this time of year) to test my new electronic setup on the 33. Managed a full pull running the boat on 6s, hit 100 mph with no problem. It's a cold weather run, so I'm very pleased with the result. I should have but did not pre-heat the lipo.
            Looks like good data log numbers, pulled 308 amps, ripple current maxed at 2.37 volts. Voltage sag was 19.1 volts (3.18 volts/cell), again with cold lipos. They went in the boat at 57 degrees, was 81 after the run.
            This answers a lot of questions for me. And brings up more questions.
            How much difference would warm weather/ lipos make? Would less voltage sag due to warmer lipos help with ripple current? Could I therefore run more prop?
            Anyway, here's the data log, zoomed in on the 100 mph pass...
            • sammyha
              • Jul 2018
              • 1038
              #276
              I also posted a video of the run and at the end of the video I went thru the data log numbers best I could. For those who can help me interpret the numbers, maybe watching me go over the data log at the end of the video would be more telling than the screenshot of the data log.
              I appreciate you all!
              Here's the link to the running video...
              • sammyha
                • Jul 2018
                • 1038
                #277
                Another question, on 8s would I have even better numbers with the same setup?
                • Xrayted
                  • Jan 2023
                  • 273
                  #278
                  Yes, cold lipos will sag voltage under hard load much worse and ripple will be higher as well considering ripple is just PWM voltage sag. This is because the colder a battery is, the higher its internal resistance goes which turns it into a crappy battery.
                  You said you went in at 57F which is just fine. Go out there when the packs are 30-40F and pull high currents, and you can damage the pack forever. Those that are purposely pre heating lipo packs for performance reasons will typically heat them to 80-100F as that gets the IR down nicely into low single digits for a good pack, but is not hot enough to cause any damage to the pack.
                  What do you mean by "better" on 8S? Better in what way? It will go faster of course, but your current values are going to scream upward as well due to more voltage/RPM and load on the model. Current only goes down with higher voltage IF the output remains the same as before. So going from a 6S setup to an 8S setup would require a lower KV motor in order to equal the same RPM output, otherwise the current follows the RPM
                  I have a 36" mono that pulls 8HP in the data logs on 6S running 75MPH with a 1716 prop. I run it occasionally on 8S with the same setup, and it hits 88 MPH, but the power jumps 50% to nearly 12HP! That's way above the motor rating, even the burst rating, so I keep those runs down to 2 quick passes.
                  • sammyha
                    • Jul 2018
                    • 1038
                    #279
                    Thank you. This is all making more sense to me...
                    • Vector
                      • Jun 2024
                      • 16
                      #280
                      I know this is older thread but have got my hands on one of these and have a question on boom tube length,
                      The sponson seem very close to the hull, measuring from inside of sponson to the tub is only 5 inches i have seen other ones at 7 inch.
                      what is the correct length of boom tubes, ?
                      Thanks
                      • sammyha
                        • Jul 2018
                        • 1038
                        #281
                        Thanks
                        The correct(stock) length is 7" from the tub to the inside of the sponsons.
                        • Vector
                          • Jun 2024
                          • 16
                          #282
                          Fantastic thanks for that.
                          Then mine are pretty short then.
                          Worst part pervious ower glued them in to.
                          Hopefully I can get them out
                          • Vector
                            • Jun 2024
                            • 16
                            #283
                            Hi all.
                            After some advice on boom tube sleeves for the Zippkits 33FE.
                            I needed new sleeves but could only
                            get longer one's.
                            Do I need to cut them down or can I just leave them long will it matter?…
