H&M Freya hull finishing
  • ArnoudRC
    • Oct 2020
    • 50
    Bit of detailing during Christmas
    Verzonden vanaf mijn iPhone met Tapatalk
    • Panther6834
      • Apr 2020
      • 708
      I like...simplistically bold.
      ~ More peace, love, and kindness would make the world a much better place
      • 1coopgt
        • Feb 2019
        • 417
        Looks great. Is it an optical illusion? It looks like your rudder isn't straight up and down. Looks like the front bottim tip is kicked back a little. If it is it may cause some issues .
        • ArnoudRC
          • Oct 2020
          • 50
          Hi, no. The position is ok. [emoji108]
          • Alfa Spirit
            • 2131
            You can make your own PDF files with wanted logos and a pro will print your file on clear or white adhesive vinyl, You choose logos and their size.
            • tubben
              • Aug 2018
              • 12
              Think there decals are from the same supplier.
              • koen
                • Mar 2020
                • 366
                H&M and MHZ they have excellent decals
                • tubben
                  • Aug 2018
                  • 12
                  Skickat fr?n min XQ-AS52 via Tapatalk
                  • ArnoudRC
                    • Oct 2020
                    • 50
                    I know. Had some high quality vinyl sponsor decals laying around. Personal touch and saved quite some money
                    • jaike5
                      • 561
                      Lose the Y fitting. Water follows the path of least resistance. I use a manifold to get full pressure to both the motor and esc. You can also restrict the esc line out with a zip ty to equalize the pressure in both lines if you choose to leave the Y in. Not a fan of restriction!
                      Happy New Year!!
                      cheers, Jay.
                      • ArnoudRC
                        • Oct 2020
                        • 50
                        Thank you! Wish you also all the best. On the y connector. You are right. I?m working on a water pump to get enough pressure through a single line (>esc> motor) Will test that setup.
                        • 1coopgt
                          • Feb 2019
                          • 417
                          Why not use a duel pick up rudder or a inhull pickup through the bottom of the boat in one of the ride pads. A lot less weight than adding a water pump. Plus you wouldn't be eating up run time powering a water pump.
