H&M Freya hull finishing
  • ArnoudRC
    • Oct 2020
    • 50
    Will start finishing this hull over the next weeks. Looking for tips to find the best quality decals. From H&M or from MHZ? Or alternatives? If MHZ, probably 84cm version?
    Thanks
    Verzonden vanaf mijn iPhone met Tapatalk
  • ArnoudRC
    • Oct 2020
    • 50
    Start is there
    • ArnoudRC
      • Oct 2020
      • 50
      Paintwork done
      • ArnoudRC
        • Oct 2020
        • 50
        Update: steering and electronics [emoji736]
        • Jesse J
          scale FE enthusiast
          • 7818
          What decals are you looking for?
          "Look good doin' it"
          See the fleet
          • Nick1979
            • Sep 2020
            • 118
            Related to the decals - if one wants to place them on the painted hull, before applying the final clear coat, will they stick well? Or should decals be applied on a really smooth surface for maximum adhesion? For example, does it make sense to spray 1-2 coats of final clear (no sanding) then decals, then a few more coats of clear?
            • ArnoudRC
              • Oct 2020
              • 50
              Strut level a good starting point for this hull? What do you think?
              • Jesse J
                scale FE enthusiast
                • 7818
                Looks good to me, I suspect it will only go up from here, but only one way to find out!
                What motor, voltage and prop are you starting with?
                See the fleet
                • ArnoudRC
                  • Oct 2020
                  • 50
                  6s, sss 4092 1650kv, x443 to start/ x445 prop later.
                  • koen
                    • Mar 2020
                    • 367
                    If you can set the prop 5mm higher less load to start with, i have a mistic 114 single motor (4092 1400kv on 6s)and run so good
                    I have excellent results with Prather props
                    • ArnoudRC
                      • Oct 2020
                      • 50
                      Ok, great. Will start with the strut a bit higher. Thanks guys
                      Technically ready to test somewhere next days.
                      • Johnc
                        • Aug 2015
                        • 199
                        Need to rotate that water jacket to get the exit line on top. Looks like the exit line is near the bottom, the jacket wouldn't fill but a quarter of the way.
                        • ArnoudRC
                          • Oct 2020
                          • 50
                          Thanks John, maybe my aquatic skills are bad. Why is that? You suggest to push the water flow upward in the jacket? In the direction below? Or do you mean to rotate the nippels facing upward?
                          • Johnc
                            • Aug 2015
                            • 199
                            Fittings on top, exit nipple should be the highest one, that way cooling can is full of water before exiting to get maximum use of the can.
                            • ArnoudRC
                              • Oct 2020
                              • 50
                              [emoji106]
