Black Pearl II Hydro - 2020
  • Reesor@work
    • Jul 2008
    • 53
    #376
    Go the TT route...your Pearl builds are already pretty darn fast. Hard to think there's more in them. Bad enough being lapped, any faster and we'll have to make the Davis' spot the field between 1-2 laps head start - kinda make it challenging for ya. The rest of us mere mortals are considering taking up scale - as in tugboats.
    Your driving - uh huh...I watched you and the other MMEU guys driving lots in the races I attended since August. Nothing lacking there! I do agree though that there is absolutely no substitute for running laps around a course. That's why I am prepared to drive 5 hours round trip to spend all day running a course. Looking forward to your build notes!
    Reesor Boat Works
    • Shooter
      Team Mojo
      • Jun 2009
      • 2751
      #377
      Here is Terry's boat running 11s laps, and some in the high 10's. It looks so smooth, you can't even tell how fast it is.
      Here is mine. Terry would smoke it in his pipe. 12s laps with one in the mid 11's. GPS was 70mph.
      • T.S.Davis
        • 6266
        #378
        Yeah but I think Tyler was driving Pete. That boat is fast but unpredictable. It will absolutely stuff without warning. It's fat from all the boats it's eaten I guess. It doesn't come off the water fly a bit and then stuff. It submerges out of nowhere. Violently. Almost always comes up upright like fresh water manta ray.
        Steve, the gang is pretty solid. I think at least. I used to run at least 9 times per month. Did that for years. Was a bit better then. Ty races twice a week minimum. Usually more. Then add boats in the summer. Sunday he raced 2 wheel. The transponders track lap consistency. Helps to tell you if your lines are the same lap to lap. He laid down a 5 minute heat with 99.16% consistency. Holy crap. Lapslapslapslapslaps. There is no substitute. Think I'll build this trial sport and bribe him to drive it. Maybe a bag of tires.
        Noisy person
        • eric113
          • Sep 2011
          • 327
          #379
          Originally posted by Shooter View Post
          For my 70mph heat race set-up, I'm running (2) 4S 5000's, and I add 5oz of copper at the CG. That probably amounts to most of the weight. My motor may weigh more as well. Personally, I've never been a fan of light boats for heat racing, but they are faster for sure.
          I think y’all run bigger motors than me. I’m running TP4050 so it smallish motor. But you’re right light boats don’t do all that well in windy, race waters.
          https://www.youtube.com/watch?v=r3ssnN1Und0
          Holy sh!t! I got some catching up to do. I need 8 more mph and I will be at 70mph on my P sport.
          But Terry also right about practicing turning laps with buoys.
          • TRUCKPULL
            • 3293
            #380
            I was finding, with my "P" if I let off of the throttle too fast and too much entering the corner. The tail end would ride up on the prop and stuff.
            I have been playing with the throttle curve to help prevent that.
            Larry
            • T.S.Davis
              • 6266
              #381
              I think that's what we were seeing too Larry. Almost better off to prop down. Slow the boat down so there's no need to check up.
              Using everything we learned on the v11 to build the v12. Every boat gets a little better. The v11 is a good boat but I think I screwed up building it like a brick crap house.
              Noisy person
              • Shooter
                Team Mojo
                • Jun 2009
                • 2751
                #382
                Eric,
                I'm running a TP 4050 as well. 2400Kv.
                  Hi Pete, do you let the glue dry after step 4 before step5? I would think so? TIA...
                  And do you use the really wide 2 sided tape or just some 1/2" wide stuff? I'm going to try what I have later today.
                  • T.S.Davis
                    • 6266
                    #384
                    I have a confession......I don't look at the instructions.
                    Noisy person
                      I got the wood building jitters. It's been a while since I've done a sporty and riggers are just square boxes easy peazy. I only cared about the center line in all my Whips because it was too much a pita to use all the squares. They all ran well regardless.
                      • T.S.Davis
                        • 6266
                        #386
                        Did you see this? Line drawn on my bench perpendicular to the leading edge of the bench. Then I lay wax paper on that so I can epoxy at will.
                        Noisy person
                        • eric113
                          • Sep 2011
                          • 327
                          #387
                          I need to get more clamps. Have that same dewalt set of clamps, but wish I had more when building sponsons and such. Right now I can only build one at time. Thanks for the center line tip Terry.
                          • Shooter
                            Team Mojo
                            • Jun 2009
                            • 2751
                            #388
                            Ray has the wood boat jitters!! Haha! Ray, I bet you've probably built more wood boats than me! I would hope Terry doesn't need the instructions. This is his 209th boat, and he designed the sponsons!
                              It's a bit OCD, lol.. I've built a few but Davis might have me beat for sure. Terry's method is a bit more simple and maybe easier for me. Getting the shelf paper to be square WRT to one edge is actually a bit of a challenge for me.
                              • jaike5
                                • 564
                                #390
                                Is that an apple juice on the rocks I see there ?
