Black Pearl II Hydro - 2020
  • longballlumber
    • 3417
    #421
    Since I cold not get a nice aluminum (long) sanding block I had to make some out of oak.
    you can get a long section of extruded aluminum square from HomeDepot or Lowes. Use a good sanding block to sand the surface flat now you have a long sanding block.
    I would agree with Terry on the sanding of the lasered end grain. The laser cutting process seems to "seal" off the end grain of the ply. Without sanding you won't get as good penetration with a glued joint. A good glue joint creates a mechanical bond between the two substrates and your glue. That's why G10 has a tendency to delaminate at the glue joint. The glue can't penetrate into a fully cured substrate (g10). Just my $.02, mileage may vary.
      Sounds good Mike. I opted for some 3-1/2" wide oak that I can staple roll sand paper to. I do use a 1/2" wide strip of 2 sided tape down the middle to keep it flat when I wrap the ends and staple the paper down. It's getting very difficult and or expensive to go the adhesive backed sand paper up here. Great planes is out of the game a Dubro isn't as good it looks like.
      I have a pair of sanding blocks now, 60 grit and 150.
      Now to setup the build board now that I'm squared away proper.
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        #423
        Unfortunately, I'm finding that more and more hobby shops are not carrying building supplies. Seems everyone wants RTW. Same with the airplane market. I glued the bottom last night. Gives me a nice excuse to showcase my collection of weights again.
        • Greg Schweers
          GREG SCHWEERS
          • 92
          #424
          That looks like overkill on the weights 50 pounds plus
            Now I know what burn marks on the surface you mean Pete. I just pulled parts out of the box, the to face is beautiful while the bottom has what you describe. Sanding today and mock up.
            50lbs does sound extreme doesn't it? lol... if it works.
            • eric113
              • Sep 2011
              • 327
              #426
              To keep the bottom flat, 50lbs doesn’t sound like alot.
              • T.S.Davis
                • 6266
                #427
                Super accurate. This is what happened to Ty's last P sport. Lasted two + seasons but eventually the belly fell out of it. There were other factors but mostly I think it was joint failure.
                For those thinking about using G10, you have to be really careful where you use it. It's tough as nails but if you are bending it much to conform to a shape it puts constant strain on the joint. You have to scuff with 80 grit and clean with 99% alcohol or acetone. Even then it's a crap shoot. Worthy trade? Meh. Depends on how good you are at fixing crap I guess. I've skinned entire boats with G10. Makes for a really stiff boat but a really heavy boat. Can't predict it's life span. Lately just my shoes are G10. Little bend so the joints aren't under too much stress but can take a hit without damage. I can also see through the G10 to know if I missed any mating surfaces when I bond them to the frames. Working so far but it's still a mechanical joint so time will tell.
                I'm sure we've all had this conversation before but for those that haven't. I think of my wood joints like this (OH sure now)...... If you glue two steel pieces like say 1-2-3 blocks together with epoxy you could probably break them apart with a few good taps from a screw driver handle. Cured epoxy is just a glorified plastic. Adhere it to a solid nonporous surface and it's hanging on fer dear life. Now imagine you epoxied two sponges together. Let the soak into each sponge a bit. Now let that cure. You might rip the sponge but that joint is forever. Same with the wood. The more the epoxy penetrates into the grain of the wood the more ONE single thing the two pieces become. If the wood grain is all sealed up with burn marks it can't penetrate. It's a judgment call on every kit if you need to clean the slots. Might take an extra half hour to fiddle fart around with them. Worthy trade? For me it is.
                This is another reason to avoid a 5 minute epoxy like Loctite or something. It will hold for as bit but the epoxy cures before it can soak into any of the wood fibers. No matrix is formed. No "forever" joint. And yes I've used Loctite epoxy to build entire boats. Worked fine......until it didn't. "Until it didn't" could have been many more heats with an epoxy better suited to the job.
                Noisy person
                • T.S.Davis
                  • 6266
                  #428
                  I use about 15 pounds myself. I end up with about 20 when I do the deck but I'm trying to cover as much space as I can. I hate decking boats. Sucks every time.
                  Noisy person
                    Yes it does.
                    • eric113
                      • Sep 2011
                      • 327
                      #430
                      It does suck. I’m still trying to learn how to glue skins down.
                      • Shooter
                        Team Mojo
                        • Jun 2009
                        • 2751
                        #431
                        I like the sponge analogy! I sanded the edges off the bottom sheet last night. It's not going to be as mean looking as Terry's, but it's the nice guys you need to watch out for! I remember Pag's daughter looking at one of my boats that had a super nice paint job and saying how pretty it was. Mike tells her "The pretty ones don't go fast, honey".
                        • lohring
                          • Jun 2011
                          • 200
                          #432
                          The bible on building wood boats with epoxies is The Gougeon Brothers on Boat Construction. I have a first edition signed by the late Mead Gougeon. Read chapter 9 on bonding.. My late father in law had a trimaran built by the Gougeons that looked like it was fiberglass. It sailed across the great lakes, down the Mississippi, around the gulf and up the east coast. He and his wife lived on it for years. It may still be around.
                          Lohring Miller
                          • T.S.Davis
                            • 6266
                            #433
                            Originally posted by eric113 View Post
                            It does suck. I?m still trying to learn how to glue skins down.
                            This wont make them perfect either but the last few I did like this. Notice the curved blocks. I use the frames to trace the shape on to the blocks and then cut them out on the band saw. Some sanding and filing to clean them up. Not perfect but pretty close to the shape. You still have to weight the flat parts and search for gaps. Wiggle, wedge, add something here or there to make sure it;s all down and as tight as you can get it. Center section is clamped with a piece of wood and wax paper in between the boat and the block just in case. I've adhered blocks there before. Really really sucks.
                            Down side is....... that's a $150 worth of bar clamps. One winter I built 5 different wood boats in about 3 months. Some simultaneously. The clamps pile up if your insane.
                            Great post Lohring. I got some read'n to do.
                            Noisy person
                            • lohring
                              • Jun 2011
                              • 200
                              #434
                              Thanks. I've used their methods on full size boats in the distant past. All our epoxy/glass Leecraft tunnels were built with West ProSet epoxy. Not inexpensive, but worth it.
                              Lohrong Miller
                                [ATTACH=CONFIG]176084[/ATTACH]
                                Nice! I like those blocks but no time to make those now. And yes some reading to do. Thanks Lohrong !
