carbon fiber reinforcement
  • tjj atx
    • Mar 2018
    • 109
    What weight of carbon fiber fabric should I use to reinforce a fiberglass hull?
    • 4340
    I use a standard 2x2 weave 3K cloth. It still conforms to the corners well enough. I've used multiple layers on particularly flimsy sections of some hulls, or in problem spots like seams.
    • tjj atx
      • Mar 2018
      • 109
      Thank you sir. That will help me out, any particular suppliers you prefer?
      • REDLINE1
        • 199
        This what I used
        https://www.amazon.com/Twill-Carbon-...gateway&sr=8-6
        • martin
          • 2881
          You can get plain weave carbon cloth or twill, the twill is easier to use on compound curves & into corners etc. Personally i prefer twill as it stays flatter easier in these areas, plain weave can lift in these areas once wetted out with resin before the resin cures.
            • 4340
            Yep, what I use is a twill weave. I misspoke when I said plain.
            • tjj atx
              • Mar 2018
              • 109
              Thanks guys. Greatly appreciated. I like that combo kit with the resin. Would Gflex epoxy work as well or should I go with a resin and hardener intended for carbon fiber?
              • martin
                • 2881
                No you want a laminating type resin & hardener like west 105 resin + the appropriate hardener to use on carbon or glass cloth ( other makes available ). Gflex is a thicker adhesive for bonding.
                • tjj atx
                  • Mar 2018
                  • 109
                  Thanks again guys. All your responses have been more than helpful.
