What weight of carbon fiber fabric should I use to reinforce a fiberglass hull?
carbon fiber reinforcement
Thank you sir. That will help me out, any particular suppliers you prefer?Originally posted by fweasel View PostI use a standard 2x2 weave 3K cloth. It still conforms to the corners well enough. I've used multiple layers on particularly flimsy sections of some hulls, or in problem spots like seams.
You can get plain weave carbon cloth or twill, the twill is easier to use on compound curves & into corners etc. Personally i prefer twill as it stays flatter easier in these areas, plain weave can lift in these areas once wetted out with resin before the resin cures.
Thanks guys. Greatly appreciated. I like that combo kit with the resin. Would Gflex epoxy work as well or should I go with a resin and hardener intended for carbon fiber?Originally posted by martin View PostYou can get plain weave carbon cloth or twill, the twill is easier to use on compound curves & into corners etc. Personally i prefer twill as it stays flatter easier in these areas, plain weave can lift in these areas once wetted out with resin before the resin cures.
No you want a laminating type resin & hardener like west 105 resin + the appropriate hardener to use on carbon or glass cloth ( other makes available ). Gflex is a thicker adhesive for bonding.Originally posted by tjj atx View PostThanks guys. Greatly appreciated. I like that combo kit with the resin. Would Gflex epoxy work as well or should I go with a resin and hardener intended for carbon fiber?
