Sniper 45" Driveshaft height above keel
  • Mike W
    • May 2018
    • 348
    Finally got a Sniper and am ready to start mounting parts. This is my first mono and I'm not sure how high the shaft centerline should be located above the keel. This will be a 8-10S T-mono local club and maybe regional race boat.
    Thanks!
    Mike
    Otto RC Marine
  • Jesse J
    scale FE enthusiast
    • 7818
    Hey Mike,
    In this case, I do a flooded stuffing assembly and a strut rather than a stinger.
    I’d allow for 1/4 to 3/4” height adjustment, to account for different prop size and/or water conditions.
    Let us know if you need some explanation or photos.
    "Look good doin' it"
    See the fleet
    • Mike W
      • May 2018
      • 348
      Wow that much adjustment? A little late for that setup I have a stinger already...maybe I'll return it. I have seen the flood tube and strut setup and understand how it works.
      But please provide further explanation on how height is adjusted for water conditions and any photos. I searched here quite a bit and most photos don't show this in detail and there is little discussion on the subject.
      Otto RC Marine
      • Jesse J
        scale FE enthusiast
        • 7818
        I think this much adjustment is the max and if you don’t have experience with a particular hull, this allows for a wide range of props and finding out how loose/wet you feel most comfortable driving. Some boats like the transom deeper than others.
        I have poked fun at Jim V when he would bring out a boat with a stinger and he couldn’t go full throttle due to blow over risk.
        Stingers are sexier... but only while on the shelf. I’d much rather have the ability to raise the prop without remounting a stinger, especially at a race.
        See the fleet
        • TRUCKPULL
          • 3293
          Not too long ago someone made a comment about a percentage measurement, from the bottom of the keel to the center of the drive shaft, for a starting position, to drill the shaft hole in the transom.
          I can not find it on the forum, and I forget who made the comment.
          Larry
          • Jesse J
            scale FE enthusiast
            • 7818
            I can not find it one the forum, and I forget who made the comment.
            Larry
            That reminds me of a movie... don’t remember the name of the lead actor or the name of the movie... but it was great!
            Larry, that cracked me up!! I’m not as young as I thought we were...
            See the fleet
            • TRUCKPULL
              • 3293
              Jesse
              I was hoping someone else remembered that comment, and could repost it here.
              It also had something to do with percentage of prop blade below the keel.
              Larry
              • jaike5
                • 564
                lmao
                • Jesse J
                  scale FE enthusiast
                  • 7818
                  Jesse
                  It also hade something to do with percentage of prop blade below the keel.
                  Larry
                  Larry, I was just having fun..
                  I hope to see the equation as well; I’m sure it could be a good starting point for stinger users.
                  See the fleet
                  • Mike W
                    • May 2018
                    • 348
                    stinger users
                    Otto RC Marine
                    • jevmax
                      Legend
                      • Aug 2007
                      • 408
                      Jesse is right about that. I flooded tube and conventional strut is always the best arrangement on a mono. Certainly more exotic fabrication is involved, but the adjustability is priceless.
                      • Mike W
                        • May 2018
                        • 348
                        OK I’m sold on the flood tube and exotic fabrication now, but I’m keeping the stinger - just had an epiphany on adding adjustability!!
                        Otto RC Marine
                        • jevmax
                          Legend
                          • Aug 2007
                          • 408
                          You can likely capitalize on that epiphany Mike. You’ve certainly got the skills!
                          • Mike W
                            • May 2018
                            • 348
                            It is done. I had to try the TFL adjustable stinger so machined a jackplate to allow adjustment with the flood tube. It spaces out the stinger just enough for captive nuts in channels behind.
                            Otto RC Marine
                            • jevmax
                              Legend
                              • Aug 2007
                              • 408
                              Ingenious Mike! You da man.
