ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • sammyha
    • Jul 2018
    • 1038
    #136
    Here's my cowling...
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1038
      #137
      Back bay is done except for trimming after it cures. Second coat of epoxy is on and brushed up the sides to the tape.
      Front bay left to do yet. Time consuming, but I like the results...
      • sammyha
        • Jul 2018
        • 1038
        #138
        Carbon fiber on the bottom is done...
        • sammyha
          • Jul 2018
          • 1038
          #139
          Some more progress and stuff coming together. Here's my quick change motor mount on the flattest part of my counter. Epoxying it all together.
          Second pic shows the stack of brass tubing for holding stuffing tube mount alignment...
          • sammyha
            • Jul 2018
            • 1038
            #140
            Final dry fit with tape marking alignment for a clean shot at placing the assembly.
            I'm placing it with epoxy applied only to the components that stay in the boat...
            • sammyha
              • Jul 2018
              • 1038
              #141
              Done!
              That's a lot of stuff coming together!
              Here's some close up detail shots too...
              • sammyha
                • Jul 2018
                • 1038
                #142
                Removal for checking/ testing concept, and doing some final epoxying...
                • sammyha
                  • Jul 2018
                  • 1038
                  #143
                  Shot of the mounting components that stay in the boat...
                  • sammyha
                    • Jul 2018
                    • 1038
                    #144
                    Here's a video showing motor removal...
                    • sammyha
                      • Jul 2018
                      • 1038
                      #145
                      And a final check of motor angle. Came out real close, I want 12 degrees...
                      • Stillwet
                        • Jul 2018
                        • 241
                        #146
                        i noticed the edges of your CF are not CA'd. on my buggy chassis and A-frames it's suggested to to super glue all carbon fiber edges so they won't fray or separate
                        Your Motor Install is Super Duper Clean
                        i bet your at the point of "Dang i'm half way there"
                        this is where i get kind of sad in my builds no matter if it's my trains, or just something for the house, it's though the journey is almost over, but wait i'll build something else, HA!
                        You do a very methodical job. This Rig should Fly.
                        • sammyha
                          • Jul 2018
                          • 1038
                          #147
                          Thanks Stillwet... It got to be a bit too much building the motor mount, but I like be able to oil my motors. I'm pretty happy with it in the end.
                          I'm not sure what you mean about using CA on the CF edges so it doesn't fray. Before applying it, or after? That's what the tape was doing before applying the CF. If you mean afterwards, it's all epoxied in now.
                          Asking to learn...
                          • sammyha
                            • Jul 2018
                            • 1038
                            #148
                            Projecting lines along the sides and top of the 7/32" brass tubing and marking with tape. Starting the hole...
                            • sammyha
                              • Jul 2018
                              • 1038
                              #149
                              Opening the hole until the 7/32" tubing slides thru...
                              • sammyha
                                • Jul 2018
                                • 1038
                                #150
                                Fitting the hole for the 1/4" tubing...
