ML Boatworks RSX380 Outrigger! My first FE wood kit build...
  • sammyha
    • Jul 2018
    • 1038
    #76
    A teaser...
    Sent from my SM-G950U1 using Tapatalk
    • sammyha
      • Jul 2018
      • 1038
      #77
      And a size comparison to the Pro Boat UL-19, and a shot with me holding it...
      • bhorowitz
        • Jun 2015
        • 109
        #78
        Nice job. Looks great. I have the 31" and that's huge by comparison.
        • sammyha
          • Jul 2018
          • 1038
          #79
          I bought the strut that was recommended in the manual. Then I see this in the ML RSX380, Big Brother... thread. Post was by MarkF, nice rigger and build.
          This strut moves the prop farther back. Is this desirable for a rigger?
          It's the Speedmaster Sport 20 strut, takes the same .187 prop shaft and 1/4" stuffing tube...
          • sammyha
            • Jul 2018
            • 1038
            #80
            Based on CraigP's feedback in another thread, I can answer my question. Locating the prop farther back is desirable. The result would be a bit less sensitivity to pitch and yaw changes.
            • sammyha
              • Jul 2018
              • 1038
              #81
              Thanks. Very rewarding to build. Like many others, I enjoy building. Nice to work with a great design too. I want to experience a bigger boat. This should be a sweet ride..
              • sammyha
                • Jul 2018
                • 1038
                #82
                I updated the list on my initial order. I will continue to do that during my build to have a more complete and accurate list in one location, as I noted at the top of the list in post #58...
                • sammyha
                  • Jul 2018
                  • 1038
                  #83
                  Looking ahead, working some things out. This is some gorgeous hardware btw!
                  This water jacket went on without a hitch. The O-rings slide nicely over the moter without lube.
                  • sammyha
                    • Jul 2018
                    • 1038
                    #84
                    I'm thinking about making hardwood stringers, and bolting them in. Then epoxy the carbon fiber mounts to them.
                    Otherwise I won't be able to access the motor mount bolts for maintenance. Or to make a motor change if necessary...
                    • bhorowitz
                      • Jun 2015
                      • 109
                      #85
                      Check out the quick change motor mounts from OSE. They have screws you can access from the top. I had the same problem on my RSX 310.
                      • sammyha
                        • Jul 2018
                        • 1038
                        #86
                        I'm not sure for how I missed this. Nice mount...
                        https://www.offshoreelectrics.com/pr...ose-AV-mount-4
                        I still want to access the side screws on the mount itself. I'll see how bolt in stringers work out.
                        • sammyha
                          • Jul 2018
                          • 1038
                          #87
                          Here's a concept sketch for removable stringers. Stringer on other side not shown...
                          • sammyha
                            • Jul 2018
                            • 1038
                            #88
                            Here's another version after eyeballing the motor angle with coupler attached.
                            It could be tied in with the stuffing tube mount epoxied to the floor block. The noted length would need to be adjusted, figuring for a prop saver in there too.
                            Here's the link for the stuffing tube mount...
                            https://www.offshoreelectrics.com/pr...prod=ose-83010
                            • properchopper
                              rcgoatbuild@snotmail.com
                              • 6958
                              #89
                              Here's how I handled the motor mount for the Aeromarine Jersey Skiff - The hatch opening was really small and a motor in/out would be a nightmare with normal mounts - With this design the motor on it's plate can be easily unbolted from above with a hex wrench on a handle. (Of course this is weighty - 'tho the Skiff handles best with some ballast - also I had intended to make the bottom plate from CF but was out of stock of CF plate at the time) - Just to give you some "food for thought" - your design is super nice
                              • sammyha
                                • Jul 2018
                                • 1038
                                #90
                                Well done and thanks for the share. So much of this stuff takes some ingenuity. It's not cut and dry. Also seeing someone's idea spawns more ideas...
