HPR 5009c bulletproof build
  • Prodrvr
    • Jul 2015
    • 701
    #121
    Originally posted by Bradb74 View Post
    Quick photo update...finished the water pickups today. Took forever to find 4mm pipe, eventually found some at a hydraulics machine shop.
    [ATTACH=CONFIG]161034[/ATTACH][ATTACH=CONFIG]161035[/ATTACH]
    What tool did you use to shape the glass? Looks very clean.
    • Bradb74
      • Sep 2017
      • 86
      #122
      I used a Dermal
      • Prodrvr
        • Jul 2015
        • 701
        #123
        I used a Dermal
        [ATTACH=CONFIG]161036[/ATTACH]
        Oh I see...used a ball end cutter. Cool, thank you! I'll have to practice on some scrap fiberglass.
        • Bradb74
          • Sep 2017
          • 86
          #124
          You're welcome, I practiced on on some scrap wood.
          Just make sure you have a firm grip on it. In my practice runs it got away from me few times.
          • Prodrvr
            • Jul 2015
            • 701
            #125
            Thanks again!
            • Bradb74
              • Sep 2017
              • 86
              #126
              Hi all
              Its been a while. My flex shafts finally arrived aftre a lengthy delay at our post office....
              Does any one know what a good C.O.G. starting point would be on my boat?
              Thanks.
                I’m still playing with mine but 30% is a good point to start. I have it written down and I’ll get the measurements for you in a few hours when I’m alive, lol
                • Bradb74
                  • Sep 2017
                  • 86
                  #128
                  Thanks
                  Got the first flex shaft installed
                    Great Brad, you are sooo close. Do you have clear water where you are?
                      Brad I have 13 3/4” of the wetted surface for CG written down. This is with a 17lb RTR weight.
                      • Bradb74
                        • Sep 2017
                        • 86
                        #131
                        Thanks, I do. There is a good size dam around an hours drive from where I live. There is also a small dam 2 minutes from my house so that's where my first run will be.
                        • Bradb74
                          • Sep 2017
                          • 86
                          #132
                          Hmmm, please bare in mine that this is my first boat so I have absolutely no idea what the wetted part is. Please will you put that into "boat building for dummy's" terms.
                          Thanks bud.
                            Thanks bud.
                            Sorry I did not get back earlier Brad. So measure the 13 3/4” from the trailing edge of the sponson. Where the stinger mounts underneath.
                            I was going to mention that make sure you have room to run this one. It’s crap till it’s up on plane and then it is GO
                            • Bradb74
                              • Sep 2017
                              • 86
                              #134
                              Thank Shawn, much appreciated.
                                • 4338
                                #135
                                COG, depends on speed goals. If this is a triple digit speed boat, you could be as high as 40%. Lipo sleds will usually provide quite a bit of balance point adjustment with heavy batteries.
