HPR 5009c bulletproof build
    Yup, looks good, nice and clean. Nice work Brad
    • Bradb74
      • Sep 2017
      • 86
      #107
      Thanks guys
      • Bradb74
        • Sep 2017
        • 86
        #108
        Hi Guys,
        Quick question, I read in this forum that guys use black silicon to mount their battery trays. Would this be advisable for my boat?
        Thanks
          • 4338
          #109
          Yep! I use black aquarium silicone sealant, recommended to me by several builders. I wish you could mount everything inside the hull with that stuff because its so easy to keep neat and clean lines.
          • Bradb74
            • Sep 2017
            • 86
            #110
            Awesome, thanks Ryan.
            • Bradb74
              • Sep 2017
              • 86
              #111
              Hi guys,
              I'd like to order my servo today. How many KG's of torque does it need?
              Thanks.
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1876
                #112
                Low profile around 10kg something like savox 1251 will do fine. But there are many servos you can use depending on wallet.
                • Bradb74
                  • Sep 2017
                  • 86
                  #113
                  Ok cool, thanks Kent.
                  • Bradb74
                    • Sep 2017
                    • 86
                    #114
                    Hi All
                    I'm sourcing some pipe for the through hull pickups. What should the inside diameter be?
                    Thanks
                      • 4338
                      #115
                      The factory inlets installed on my HPR are made from tubing that measure 0.166" which is a little over 4mm on the inside diameter.
                      • Bradb74
                        • Sep 2017
                        • 86
                        #116
                        Cool,
                        Thanks Ryan
                        • Bradb74
                          • Sep 2017
                          • 86
                          #117
                          Photo update..
                          Servo and ESCs are in.
                            • 4338
                            #118
                            Looks awesome
                            • Bradb74
                              • Sep 2017
                              • 86
                              #119
                              Thanks.
                              • Bradb74
                                • Sep 2017
                                • 86
                                #120
                                Quick photo update...finished the water pickups today. Took forever to find 4mm pipe, eventually found some at a hydraulics machine shop.
