HPR 5009c bulletproof build
  • Bradb74
    • Sep 2017
    • 86
    #46
    The quality looks good to me. I've never seen an older older one in the flesh though.20171205_204229.jpg
    • Bradb74
      • Sep 2017
      • 86
      #47
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        #48
        Here is one I'm building for a customer
          • 4338
          #49
          [ATTACH=CONFIG]155370[/ATTACH]
          Who makes the rudder hydraulic arms?
          I also see an uneven transition from the tunnel to the bottom of the rudder stand-off. Perhaps this is one of the differences between old and new C5009's.
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            #50
            Me, :-)
            • nata2run
              customcfparts.com
              • Nov 2011
              • 1876
              #51
              @ fweasel, you sure you got a 5009?? ( also see an uneven transition from the tunnel to the bottom of the rudder stand-off)
              • nata2run
                customcfparts.com
                • Nov 2011
                • 1876
                #52
                the yellow is an original 115 HPR from Hans, and the white the 5009 also from hans, same size but different hull type...
                  [ATTACH=CONFIG]155376[/ATTACH][ATTACH=CONFIG]155377[/ATTACH]
                  The sides of the pedestal depressions are also different. Any other difference my friend?
                  • nata2run
                    customcfparts.com
                    • Nov 2011
                    • 1876
                    #54
                    The hulls have not changed they are different hulls
                      Yes but are the tunnels and such the same? Does one favor handling better or anything Kent? I know we had discussed that a HPR can handle but I’m curious if any are better? I did not actually know the 5009 was any different. I thought maybe the hatch orsomething.
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        #56
                        They are both great, would say the 5009 is more for straight and the 115 handle a bit better
                          • 4338
                          #57
                          Me, :-)
                          Can't find them on the site last I looked, and the site doesn't even load for me now. How much/where?
                          Here's a shot of the bottom of my hull at the rear. My rudder standoff to tunnel transition is smooth/level. My hull looks exactly like photos of a Bulletproof C5009 that KBB built down to the locations of the hatch bolts and water inlet/outlets.
                          • nata2run
                            customcfparts.com
                            • Nov 2011
                            • 1876
                            #58
                            If you need hydraulic or any other parts you can hit me up
                            • Bradb74
                              • Sep 2017
                              • 86
                              #59
                              Hi Kent
                              I'm going to send you a PM.
                              Thanks
                              Brad.
                              • nata2run
                                customcfparts.com
                                • Nov 2011
                                • 1876
                                #60
                                Brad if easier catch me on FB nata2run
