i also need to start thinking about powering this thing.
ML Boatworks GP310 build
It seems every build hits it's rough spot... I know the feeling!Originally posted by Luck as a Constant View Post[ATTACH=CONFIG]154166[/ATTACH][ATTACH=CONFIG]154167[/ATTACH][ATTACH=CONFIG]154168[/ATTACH]I got some 1/4 aluminum, marked the holes then drilled and tapped it before glueing in. I used a small amount of glue when glueing so I didn't get it near the threads, and used the bolts to glue into place to be sure everything lined up proper. That whole part of this build was a bit of a chore for me, but now it's done and I can move on.
yeah, and i am being rather anal about this part too. i wanted to make sure the mount is seated square to the bottom of the ride pad. i made sure to also drill out any mounting hole just a mm larger than the bolts holding them. a tiny bit can make all the difference when tuning it.Originally posted by CraigP View PostIt seems every build hits it's rough spot... I know the feeling!There's a hole at the center of earth where the rest of the world sinks but i stand still...
Yep, you need tweaking room! I found the turn fin to be the most sensitive and productive tuning, even more that the strut. The strut is pretty basic, prop shaft centerline at depth of back of sponsons. I always try to achieve a zero strut angle, that just seems to be a tweak trying to fix another weakness. Sure looks good, enjoy it!
It's a rudder bracket from speedmaster. I'llOriginally posted by CraigP View PostNo, I think he's talking about the angle bracket... it looked a little thin to me too...
Measure it later but it's not a flimsy pieceThere's a hole at the center of earth where the rest of the world sinks but i stand still...
Last night I got pool noodles in everywhere, then glued the deck on.
sorry for my lack of detail lately. all i did was get out the west systems, coat the area the deck was going on, then coat one side of the deck itself, then used weights, tape and clamps where i could to get it in places.
all setThere's a hole at the center of earth where the rest of the world sinks but i stand still...
Nice looking build! Keep up the good work! MikeLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
I have been watching actually! I just dont always post, hahaLaser cut, birch plywood rc race boat kits- WWW.MLBOATWORKSRC.COM WWW.DINOGYLIPOS.COM
