So what is the word for "tube" in French?
head of the river cat hull thread
Servo choice.......
Can anyone tell me any reason not to use a small servo? In my original build I fitted it with a 9Kg/cm Tower Pro servo, I also have this servo in my 48" Riptide and that weighs like 18Kg....
So with this being so much lighter and with the twin drives, Can I use a small servo like a HiTec HS82MG?????
I know I can lay the servo on its side but I still would like to use my original steering setup and put the servo in the sponson over one of the flexies....
Also, I did see a drawing on here for motor plates and I thought I copied it to my desk-top but looked today and it's not there???
Does anybody know where it is as I can't find it???? (The one on here! NOT the one I copied!!!) Lol!!!!Last edited by KillerDave; 01-21-2010, 04:11 PM.HPR C-5009, Riptide48, PaynPak 1/12, Miss Budweiser 1/8 Hydro, Miss Freya (own design 1/8 Hydro), HOR 32, Twin 380 HOR 32, Magin one
Problems ...any ideas????
I have the hotr cat and have set it up with the following a FSD brushless 2074kv motor with a seaking 150amp esc and a x440 prop on 2 x 7.4 so 14.8 volt... the problem im having is that the boat is slow as....first thing i did was lft the seg as height as it would go (prop nelly touches rudder parts) and also have tryed many different places for the battery's and no luck....so would anybody have any ideas for my im starting to get unhappy and the poor boat might cop a 22 odd volt hamming if it don't work bloody soon...please please help a first time boater out...HOTR 32" Neu 1515 112 kph / Etti Demon rigger 3s leopard motor / 36" r2 hobbies twin tunnel with leopard 2200kv / Delta force 22 Hydro with dirty 2 pole motor / mini bolt with 380l motor good for about 60 kph
Ooops..... what packs??
C rate,
Mah
Brand
You may not be able to pull the amps you need or want from your packs, prop may not be right, could try a x442 or x640 instead, post pictures...
x440 prop .... 20 c 5000mah pack reedyHOTR 32" Neu 1515 112 kph / Etti Demon rigger 3s leopard motor / 36" r2 hobbies twin tunnel with leopard 2200kv / Delta force 22 Hydro with dirty 2 pole motor / mini bolt with 380l motor good for about 60 kph
is this your drifter? if so, how do like the hardware? i see its way far back off the transome, i asume it stays dryer at high speeds. also can you give me a link to purchase one please.Originally posted by Alfa Spirit View PostI don' t like
I prefer Maritimo style or something like this Drifter
I think you could do a bit better with 4S2P 40C cells Turnigy, or Zippy.
Longer run time and more available power to motor.
I don't think those cells are cutting it, they were meant for RC cars that don't draw nearly the current your motor does.
I bet it does NOT get very warm when you run it, does it???
Thats a nice cat!!
Drifter S
I Thank you very much ...i thought it might be the case but wasn't sure off to get some new lipo'sOriginally posted by ray schrauwen View PostI think you could do a bit better with 4S2P 40C cells Turnigy, or Zippy.
Thats a nice cat!!
Drifter S
would 30c-40c be better????HOTR 32" Neu 1515 112 kph / Etti Demon rigger 3s leopard motor / 36" r2 hobbies twin tunnel with leopard 2200kv / Delta force 22 Hydro with dirty 2 pole motor / mini bolt with 380l motor good for about 60 kph
30-40c is fine.
Hobby City's 40c -50c cells aren't in stock, well, not many but, 30-40c will do and maybe less$$$...
Cheers for the info... a mate had some 35c 5200 mah batterys and i took the boat for a spin yesterday and it went like a cut cat cheers for info you have saved my boat from a 22 volt caneing....
just ordered some 4000mah 40c from hobby cityHOTR 32" Neu 1515 112 kph / Etti Demon rigger 3s leopard motor / 36" r2 hobbies twin tunnel with leopard 2200kv / Delta force 22 Hydro with dirty 2 pole motor / mini bolt with 380l motor good for about 60 kph
I use prop adapter 3/16" to 4mm, that' s perfectOriginally posted by FastVee View PostHey guys... that artr cat looks good, but is that shaft 4mm?
http://cgi.ebay.com/32-catamaran-ART...4.c0.m14.l1262
If so, will 3/16 go there or do I need a new strut? (or is that 4mm durable, I can use 3/16 adapter on my props too)
Is that paint or decal they have on them? -would like to get a white or black hull instead.
And If some one knows the hardware quality on this artr or the parts they sell at hotr, please do tell! -like this http://cgi.ebay.com/aluminum-rudder-...4.c0.m14.l1262
I need to order 2 hulls or artr“s soon(one is for matti1983).
Steven is out of stock on these hardware parts so it looks like i need to order everything from hotr.
thanks,
Pate
