head of the river cat hull thread
  • Tony
    • 420
    #241
    Originally posted by Jeff Wohlt View Post
    I cut a piece of ply and epoxied it in the strut holder. Before it hardened too much I drilled and used blind nuts...I had to use hemostats to hold the nuts to get them started...a real pain but worked and they are not moving. Now I can remove the bolts and nuts stay there.
    Just need to finish the cooling in mine and it is ready. 8XL, 4S and Etti 150. Probably start with m440 and end up with a 640. I am going to push one of my 62 wires in it for now but was built for 078 wire.
    Jeff, Are you using Etti 150 with BEC? Mine is 9xl, 4S, Etti 125, and 642 prop. Wonder why no one is running with x445 prop...
    • 785boats
      Wet Track Racing
      • 3423
      #242
      Tony.
      When I had the SV27 package in mine I tried a 445 & a 645. Seemed to have a lot of prop walk & was very unstable in the corners.
      With the 8XL motor in it now the biggest I run is a 642. The 640 is the one I run most of the time though. Good speed, good handling & good temps.
      Never tried a 445 on the 8XL. I'll have to replace the bearings first though, they're sounding a bit rough.
      Surely someone else has tried a 445 or 645 in this boat.
      Cheers.
      Paul.
      • Tony
        • 420
        #243
        Tony.
        Cheers.
        Paul.
        Paul,
        Which ESC are you running with the 8XL?
        • Jeff Wohlt
          • 2740
          #244
          Actually my etti is only 125 amps but is good with BEC...special made unit.
          a 445 might be perfect...not sure yet but I will play with all of them.
          I usually am just looking a 4-5 minute play run...not racing...lots of speed in the straights is what I like.
          Because of that hull I feel staying a bit smaller on the 8Xl is going to be key to maintain good cornering without torque problems or chine walking.
          We will see. I just need to finish it up. Certainly a great looking cat but I would consider filling the nose with some foam...I hear they crack open when doing an end - to - end dive. I plan to just do some spray in foam a little at a time until I feel it is enough with expansion. It also sticks the top and bottom together where chunk foam does not.
          www.rcraceboat.com
          jwohlt5362@yahoo.com
          • ozzie-crawl
            • Sep 2008
            • 2943
            #245
            7xl with a 440/3 runs real nice, 55mph and no real prop walk
            • pbleckert972
              • Jul 2009
              • 124
              #246
              anybody know how fast the rtr is stock on 4s?
              • Tony
                • 420
                #247
                stock rtr The motor is not strong enough to push that hull.
                • BIGDG357
                  • 270
                  #248
                  Finally , I can get a little progress on this thing. I got my hardware from OSE today I will have to shim it off of the transom to give the steering arms a little extra room. Thats a piece of carbon fiber in there now but that one is going to be moved into the inside of the transom for support and i'll cut a new one a little nicer for the shim. I see i'm not the only one having trouble due to the quality of this hull the steering rams will have to be angled and scribed on the mounting side to sit flat and not bind up becaus of the transom not having a flat mounting surface but I love the look of them so whatever it takes they are going on there. Here is a few pics with every thing sized up and taped on for measuring
                  • bonewar
                    • 587
                    #249
                    !!!!!SWEET!!!!!
                    • BIGDG357
                      • 270
                      #250
                      Originally posted by bonewar View Post
                      !!!!!SWEET!!!!!
                      thanks man those are the MHZ rams you told me about .THANKS
                      • BIGDG357
                        • 270
                        #251
                        OH' but I did have to modify them to fit, I had to cut the bottom mounting tab off and drill a new hole the transom is very thin on this hull
                        • ksm2001
                          • Jun 2007
                          • 397
                          #252
                          Sweet
                          BTW Scott nice carbon fiber job , what did you use for finishing resin with the carbon fiber?
                          Ken
                          • ozzie-crawl
                            • Sep 2008
                            • 2943
                            #253
                            being no expert with resins i just use a laminating epoxy (i think) thats used if your doing multiple layer, its a little sticky for awhile after it dries but after i finish doing motor/servo mounts i use some carnauba wax,gets rid of the sticky
                              • 9481
                              #254
                              Wow! 55mph with a 7XL, I wonder if I could use that motor in my MM and get the same speeds?
                              • pbleckert972
                                • Jul 2009
                                • 124
                                #255
                                anyone seen this?
                                http://cgi.ebay.com/New-RC-2CH-Elect...d=p3286.c0.m14
