head of the river cat hull thread
  • rc123
    • Sep 2008
    • 34
    #211
    a water pick-up behind the prop works best in my view
    hotr to Europe in 2 weeks
    • FastVee
      • 659
      #212
      -i had that pick up on my HOTR order! -but I did not get where to install that...so I did not order it after all...Wish I had seen that pic few hours a go
      I will order stuff tomorrow from OSE, anything there that is good to use s water pick up?
      What about the Gundert water pickup ? -I guess I can cut that cat too...
      www.youtube.com/rangerpate
      • rc123
        • Sep 2008
        • 34
        #213
        you may find an ideea of how to build quite easy a water pick-up.
        also on mine I needed to adapt a little bit even with the kit from china.
        • ED66677
          • 1300
          #214
          yeah a 4mm ID tube behind and above the prop!
          Emmanuel
          • FastVee
            • 659
            #215
            I am sure that would work, but I am trying to make this look like real 1:1 offshore boat, they dont have 50" drainpipe stuck on their rudders
            So any1 tried that gundert pick up under the sponsons? -water exits on side or on transom for looks(gotta have chrome exits!)
            Pate
            • ozzie-crawl
              • Sep 2008
              • 2943
              #216
              if you are going to get this strut/rudder from o.s.e it has a built in water pickup
              http://www.offshoreelectrics.com/pro...rod=tfl-502b15
              • FastVee
                • 659
                #217
                Yes, that is the one I´ll use.
                I´m not sure that is enough, that´s why I asked.
                • ozzie-crawl
                  • Sep 2008
                  • 2943
                  #218
                  unless your using some really hot setup then it will be fine, if you have heat issues then more cooling isnt really going to help.
                  i have used that strut/rudder on the hotr hull running 6 and 7xl motors with no problems. what setup are you looking for long run time or chasing gps speeds
                  • FastVee
                    • 659
                    #219
                    I guess that I´ll start with the 8XL(since I have it allready) and HImodel 200A esc.
                    I only have 2S1P lipos, so 2X2S1P(4S) it is then.
                    I started doing some decals too,first sheet is printed!
                    Pate
                    • rc123
                      • Sep 2008
                      • 34
                      #220
                      I was running a KB45 so I needed the extra cooling...
                      The water pick-up on the rudder works only at speed but should be fine.
                      • ozzie-crawl
                        • Sep 2008
                        • 2943
                        #221
                        8xl on 4s is a great setup with these hulls, a x642 will see you around the 50 mph mark just watch run time (tho should be good for at least 3-4 min depending on battries), if longer run time is wanted try a m440 or a 440/3
                        just start of small and work your way up
                        • ozzie-crawl
                          • Sep 2008
                          • 2943
                          #222
                          should mention as well if your going to start pushing this hull above 50 mph add a layer of carbon fibre down covering the tunnel down in the sponsons and up the sides covering the seam,they can split at the seams and if you flip hard enough crack the sponsons
                          • ksm2001
                            • 397
                            #223
                            Great thread guys thanks Scott for your comments, like Pate I'll be building one over the winter so these are some answers I'm looking for also since this will be my first cat.
                            Did notice also that the hull is a bit thin so I'll carbon fiber the tunnel and sponsons, also noticed that the fiberglass seam tape only goes along part way to the back and front seams, thanks for mentioning that they can split, l'll carbon fiber those areas also.
                            Ken
                            DF-29,Phil Thomas Super Sport 45, SV27, Xzess 2 Evo, HOTR 32" Cat
                            • FastVee
                              • 659
                              #224
                              Steven has the hardware in stock! He had one black anodized but it has mysteriously disappeared
                              Just to make sure, this is the one we want on this cat, correct?
                              Pate
                              • ozzie-crawl
                                • Sep 2008
                                • 2943
                                #225
                                thats the one
