It has one from HPR, and seams doubled. I did this to my Fantasm which is on its fourth year(or fifth), with I don't know how many crashes and it is still fine. This takes the possibility of the deck flexing out of the equation. I also do it to my monos.
All your extra precautions will pay dividends down the road as you know. All my hulls that have layups seem like they could easily do with more.
What epoxy do use use for the cf tryed some two part but it didn't hold on 3mm sheet ordered some zap to try. didnt cloth those parts just was checking out some things.
Have been looking forward to this build for quite some time, sometimes when the lake ices over its a good thing forces you to build lol.
I like the stringers, need to do some thinking about bulkheads for some of my boats too. Did one a few years ago on a super daytona and it really helped out.
Do u foam the sponson tip's with foam also or no? On my esc's sf 300pro + i used the Hifei cap packs solder the 4 wires on the back has 8mm bullets for wire connections on the front for battery's easy setup for parallel or series setup. unless those cap banks aren't good???
Ah' I didn't think of that. But my space is going to be tight as I am putting the esc's in the sponsons. But I will investigate!
As far as foam, this is still weighing in my head. I have two new Kintec foam kits here so I think i will. I am leaning that way. I did it on the last couple boats.
My apologies that i did not take pics of the method for squaring the pedestals, the next time th boat is upside down I'll take a pic and put here. But what I did was run two K&S tubes thru the bearings within the drives extending rearward the length of said tubes. You can then measure the distance between them front and back to maintain square drives. Use a marker to dot the pedestal holes and there you go.
