The Black Pearl P Sport Hydro 2017
  • Shooter
    Team Mojo
    • Jun 2009
    • 2520
    #91
    Yours is a V5.7, Ray. Same as the boats in post #1.
      • 9438
      #92
      M spec is the future. LSH is the past. haha
      Did I miss a thread? I'm lost.
      • T.S.Davis
        • 6228
        #93
        http://forums.offshoreelectrics.com/...pplement-rules
        It's experimental in truth Ray. We're not looking to fix P limited. Limited was NAMBA so I couldn't possible care less if that ever gets fixed.
        This is something new. We like to think of it as the next generation of spec racing. Idea is that you get to choose......or don't choose....... The equipment we've used for years in the old limited classes works up against this new spec. Proved that in AZ. Ray was cleaning up. Ty's limited offshore was right in there with the old tech too. I ran a TP. Ty had a Dynamite and we finished a 1/4 lap apart I think. So you don't need to upgrade (side grade?) unless you just want to.
        Noisy person
          • 9438
          #94
          ...and found.
          Thanks for the details. My yellow cans are showing signs of impending death so I invested in some blue cans cause they were a darn good deal.
          I look inside the Dynamite and see a crap load of copper, not so much in the yellow cans... I sold my one TP motor long ago and that was a mistake. Oh well... blue it is for me for now.
          I find it a PITA that a spec motor costs almost as much a an open motor. That's silly but a reality none the less.
          • T.S.Davis
            • 6228
            #95
            That's what we're checking on Ray. I just don't believe that paying 100's for a motor is going to net a reward in this class with a size limit. There are some really good motors for cheap now. Those blue can Proboat motors are the real deal.
            Noisy person
            • Shooter
              Team Mojo
              • Jun 2009
              • 2520
              #96
              I cut the pcs for the new nose pc. It came together nicely. The previous nose weighed in at 5.6oz, even with the relief holes. The new one only weighs 1.5oz!!!
              • Shooter
                Team Mojo
                • Jun 2009
                • 2520
                #97
                The top and bottom sheeting fits like a glove. Very happy with how this came out. I sanded the bottom face edges at 45deg to compensate for glue fillets underneath, and to allow more surface area for glue to adhere.
                • TRUCKPULL
                  • 2971
                  #98
                  Pete
                  I see you found some 1" 1/2 round.
                  Larry
                    • 9438
                    #99
                    Can this mod be added to a 5.7 to make the build easier?
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2520
                      #100
                      Larry, I never found 1" half round. I ended up cutting 1" dowel in half on the band saw. Not easy. You can't twist it.
                      Ray, Yes. I can cut you some nose pcs next time I'm out there if you want. It will definitely save you time.
                      • TRUCKPULL
                        • 2971
                        #101
                        How about two pieces of 1/2" Quarter round??
                        Larry
                        • detox
                          • 2310
                          #102
                          Would 1" foam be lighter ? Easy to sand to shape. You could skin it with stiff fiberglass or thin plywood.
                          • T.S.Davis
                            • 6228
                            #103
                            Larry
                            Great idea Larry. You could even trim out some of it before you joint the two halves. Even more weight savings.
                            Noisy person
                            • T.S.Davis
                              • 6228
                              #104
                              I fabricated the nose of an 8255 Oberto from two part foam. Lots of easy sanding. Then glassed it. Light and strong as nails.
                              Noisy person
                                • 9438
                                #105
                                That would be VERY helpful, thanks!
                                I'll let you know another day. Not in a big rush.
