Light version in process! Mine won't be nearly as light as Terry's.
The Black Pearl P Sport Hydro 2017
You can get creative and make a lot of parts (sponsons, nose piece, etc) from foam. Cutting foam with hot wire or sanding to shape, then coating with fiberglass. Spray a light mist coat of 3M spray adhesive to shaped foam. then lay down fiberglass cloth and epoxy. Lots of videos on YouTube.com that show how. There are lots of old RC Airplane tricks.
What? You are finally making a longer more stable version. You will see that it will turn just as good as the shorter version. And be more stable down the straits without blow over. CoolOriginally posted by ray schrauwen View PostWow, a 34" hull in specky class. Things are changing...
Unleaded...........
whiplash 424.jpg[Last edited by detox; 03-10-2017, 01:20 PM.
It is still 33.5" long. I do plan on a smaller (lsh size) and larger (Q size), but not immediately. I understand your comment regarding a longer hull though, similar to a dragster or funny car keeping its front wheels on the ground. I see you have an extended strut. That's a good idea. I took a different approach with this hull. It has tapered air bleeds that keep the pressure underneath to a minimum. I haven't heard of anyone blowing these over, even at speeds in excess of 65mph.
Here is mine... she aint black but she has some pearl.
still gotta add motor and esc...
It is very nice. Thank you for sharing pictures. I like that you left most of the bottom unpainted wood.
Did you get the Speed Master stuff anodized or did you buy it that way? Turn fin mount at first I thought it was from an RC car part then I saw the back.
I LIKE!!!!
