The Black Pearl P Sport Hydro 2017
  • donthavta
    • Jul 2009
    • 186
    #256
    The 620 doesn't count this years
    • donthavta
      • Jul 2009
      • 186
      #257
      Well, I have now read the 256 posts for 2017 ! have taken lots of notes . Have dry fit my 5.7...ride pads all 5mm , stick built nose with 1 inch Will use foam for round glassed (Thanks to Terry ) .does the Air dam work ? looks like 1/4 stock ,is one side longer then the other ?
      • Shooter
        Team Mojo
        • Jun 2009
        • 2520
        #258
        Air dam? Are you talking about the AOA adjustment in post #211? Yes, it works, but I don't think it's necessary. John Gross has that boat now. It runs very well.
        • donthavta
          • Jul 2009
          • 186
          #259
          Yes ,thanks ....my build will start late this week. Ron
          • detox
            • 2310
            #260
            Originally posted by CraigP View Post
            Agreed. Putting a bunch of weight in the back and counterbalancing it with weight up front just makes a see-saw. The boat will porpoise badly!
            Strut is adjusted too deep causing front sponsons to ride without angle (too wet). This can also happen to a lighter weight hull if strut is set too deep.
            • Moonie
              • Jan 2014
              • 342
              #261
              Originally posted by TRUCKPULL View Post
              Pete
              I got mine running at 70 with NO added weight.
              Larry
              What prop you use to do that like a 47 or 50?
              Gold Spilo
              • T.S.Davis
                • 6228
                #262
                Well yeah but it's all over the place. In fairness though, that's probably Larry's fault.
                Noisy person
                • CraigP
                  • May 2017
                  • 1464
                  #263
                  Too much rake in the prop, especially on light hulls, can also cause these symptoms.
                  • TRUCKPULL
                    • 2971
                    #264
                    Antonio
                    The hull that runs 70mph is one of the old 5.7 kits
                    This build and hull is a lot heaver then the new light weight kits.
                    It also has some of my own mods built in.
                    It is a full "P" setup
                    NEU 1515 - 1Y - 2200KV
                    Two 4S - 5000's 65-130C
                    Castle Hydra 240amp
                    Timing set to 15 Degrees
                    ABC - 1815 -17 -45
                    Build thread:
                    https://forums.offshoreelectrics.com...10-Black-pearl
                    Pictures
                    https://forums.offshoreelectrics.com...p?albumid=1364
                    I have since changed the turn fin, to make the hull more steady and run true without pulling to the right.
                    Also had to replace my drive tube, due to a dent in it that I did not notice, - lost two shafts at the last race.
                    Larry
                    • CraigP
                      • May 2017
                      • 1464
                      #265
                      Larry, what are the pertinent restrictions for P Sport? I have a 2310kv TP motor and two batts like yours.
                      • photohoward1
                        • 1629
                        #266
                        No restrictions for motor in P Sport. Spec is 36x60 mm
                        • T.S.Davis
                          • 6228
                          #267
                          2310 is pretty hot. Which motor is that? 4070? It could work with a small prop. The 1515 runs warm too at 2200kv.
                          For me, I prefer a few less kv with more blade in the water but results vary depending on which boat you're running. Some boats don't like a big blade. The Pearls do pretty well on 45mm props. A 45mm on a TP2310 will likely come in hot on the oval. Zip zip playing around it will work fine though.
                          Noisy person
                          • CraigP
                            • May 2017
                            • 1464
                            #268
                            It’s a 4050 TPP motor. Heavy hull, about 10.5#, so I figured a bit more motor bog... Yes, M445 is the best prop. And you are right, it is very hot heading into the corners! I have to back off throttle at same time I slam the rudder right. Scrubs off some speed by the apex, then more slowly straighten out while feeding back to full throttle. It’s a handful... I’m waiting on a mixer to install in the boat to handle that rudder/throttle ballet dance. Hopefully I’ll be able to put more attention to the track.
                            I haven’t even tried turning full throttle, just feels like a suicide mission, lol!
                            Oh, Boat does not like big prop/lower kv setup.... It will start to porpoise if I hit any rough water. Little prop/high kv and the boat just hops up, flies level, then sets back down.
                            • CraigP
                              • May 2017
                              • 1464
                              #269
                              That’s a small motor! So folks need a very light hull in Spec with that small motor? I got a 3674 in my DF29 Mono...
                              • T.S.Davis
                                • 6228
                                #270
                                Usually those boat are light. There are tons of options though for motors.
                                Noisy person
