My first Build
  • boredom.is.me
    • Jun 2009
    • 626
    Find a prop that fits your boat, not the other way around.
    • Newboater
      • 359
      Motor is 1500kv going to need a bigger prop as going to be running on 6s
      • Newboater
        • 359
        I have no experience with that hull, but on my 29" cats, the strut sweet spot was a good 3-4mm above the bottom of the sponsons, at a neutral trim angle. I could place the boat on a flat table without a prop, and the strut and stuffing tube would not touch.
        The hole through the hull I made is probably too small. going to increase it a bit to get a better angle. Started small as I didn't want to have to try and add material back to the hull.
        • Newboater
          • 359
          Yeah
          Native Paul set me straight The hole I made in the hull was to small. Increased it by 1/4" and the universe aligned. Perfect stuffing tube just need to trim the length a touch as straightening out the stuffing tube made it a bit closer to the motor and the tube is almost straight.
          Pictures
            • 4338
            and all is right again with the world. Glue away!
            • Tamelesstgr
              • Jun 2014
              • 1512
              Just curuois how hard was it to get rid of the JB Weld when you re-did the stuffing tube?
              NEVER SATISFIED RACING
              Fine Design 32 V-Hull 4082+6s
              • Newboater
                • 359
                Actually really easy. I used a hot air gun till it started to soften and it came right out.
                • Newboater
                  • 359
                  Yea I am so excited. Spent the last 3 days outside in 25* weather fixing my daughters jeep. It is nice to finally have something go well.
                  • Tamelesstgr
                    • Jun 2014
                    • 1512
                    Thanks for the tip
                    • Mxkid261
                      • Jun 2015
                      • 734
                      Looks better
                      • Newboater
                        • 359
                        Originally posted by Mxkid261 View Post
                        Looks better
                        Thanks by opening the hull a little I was able to keep the bend at 10-15* angle which is pretty mild.
                        • Newboater
                          • 359
                          Well between the problems with my daughter's jeep and then loosing both the front wheel bearings in my Toyota, I didn't think I would find time to do anything on the boat. Anyway yesterday and today were quiet and rainy so I took advantage of it. Also added the hatch bolt kit. Basically ready for paint.
                          • rayzerdesigns
                            • Dec 2013
                            • 1228
                            Originally posted by TheShaddix View Post
                            As a general rule you want the strut always inline with your sponsons, not below or above. This way it won't be creating any drag. Only your prop and the bottom of the strut should touch the water. When you set the boat on a flat table you should have all of the 3 parts touching down evenly. If you find that your prop is too small, put a bigger prop on. Only half of your prop needs to be in the water when it's on plane.
                            I disagree..on my gas cat it's almost even.. but everyone of my electric cats are at least 2-5mm above bottom of sponsons..
                            • TheShaddix
                              • Sep 2013
                              • 759
                              Any reason yours are 2-5mm above bottom of sponsons...? Is there any advantage? I am not trying to argue the point, I was just under the impression that it's best to have the prop hub as close to the water as possible so the full blade (one of the blades when it's down) is in the water.
                                • 4338
                                I'm not experienced enough to tell you why, but when I was tuning my Blackjack 29 V3, the sweetspot for the strut was about 3mm above the bottom of the sponsons, all other factors being equal. I started with it dead even and picked up speed as it was raised.
