Originally posted by Tamelesstgr
View Post
Project VooDoo mono build
Always enjoy seeing your builds, inspires the rest of us!
Looking good Trav, I like the bright color 2 tone idea too, will help it be visible at the far end of the pond.
Also, good news is if you happen to break a hammer you have a few spares....
Hi, I really like these threads. Fantastic.
Perform the reinforcement with epoxy + carbon shredded at the ends. And finish covering the entire hull with CF twill. Covered in pieces. The parts are framed by black cloth tape (electric / automotive tape). That cut to 2mm to ensure the fibers.
May I ask if you take special precautions for your personal safety?
Try to wear gloves, face masks and glasses most of the time. What little I read about carbon led me to use more protection.
Buy that lime green for my boat. Epoxy paint. It looks very nice.
Nice Travis and YES Golfito is absolutely right about safety when working with any kind of fiber,,,mainly sanding with a powertool....I think this is the main Con of fiberglass boats besides being my production boats.GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
Looking good! But one thing I don't understand is using masking tape to cover the entire hull. Doesn't that leave residue and is difficult to remove after a few days? When I mask out some cf pieces the tape is always hard to peel later. I guess I am confused because it'll be sanded/painted later anyway. Seems like a lot of tape wasted and you can still technically damage the hull through the tape. Or is this mainly so you don't drop epoxy on it?
Originally posted by golfito View PostHi, I really like these threads. Fantastic.
I wear a mask when cutting it, sanding it etc. once the epoxy/cut carbon reinforcements are done, I'll do an inlay the will go u all the way both sides. I try to use one piece. If I don't think it's stiff enough I'll do two layers or a layer I've carbon and a layer of Kevlar under it. I haven't even flexed the hull just yet (what I normally do to gauge how many layers....by pushing on it to see how much give it has)32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
Well I use expensive 3m tape only. I've left it on for months and never had an issue with peeling it off. It might be because the temperature in my should doesn't get to extremes. I leave the air on auto in the summer and try to keep it below 88ish. The purpose is epoxy will get on it. I'll scratch it etc. might slip with the drill. Might drop something on it. I had it propped up tonight right before I poured epoxy in the tip and of course I knocked it over on the floor. It was padded where it fell over but just an example of my luck and sometimes clumsiness.Originally posted by TheShaddix View PostLooking good! But one thing I don't understand is using masking tape to cover the entire hull. Doesn't that leave residue and is difficult to remove after a few days? When I mask out some cf pieces the tape is always hard to peel later. I guess I am confused because it'll be sanded/painted later anyway. Seems like a lot of tape wasted and you can still technically damage the hull through the tape. Or is this mainly so you don't drop epoxy on it?32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I guess it's that time. To do a really nice and neat job I do a mono a little different than a cat. I put the carbon fabric in dry. This hull is very stiff and really doesn't even need any carbon but I insist on doing it because grease and all that looks nasty on tan looking fiberglass. The carbon really dresses it up and it stays cleaner looking. The key to success here is making sure the epoxy soaks through. It's 65f in my shop right now (37f outside) and I have my epoxy a few feet from my heater so it will get a little thinner so it will soak in better. This may not be how some of you do it, but it works for me. I could put a coat of epoxy first then install the cloth but I'm wanting it lined up perfectly straight and I've never had it lift because I know how to get it soaked through. The only thing is to get it wet enough to soak it throughly I'll end up wasting some epoxy because I'll be soaking a bit back up. O well, sacrifice I'm willing to make for it to be perfect. I want this thing show quality.
Really great that you go into all that detail in your posts. I'm sure a lot of people appreciate that even if we don't mention it. There is always something new to learn! The inlay looks great. How do you keep that masking tape from separating when soaked? I tried this method but mine always came off and made a mess with carbon fraying, etc. Now I just use fabric glue, but the downside is that it takes time to cure. Oh, and keeping your epoxy by a heater is a neat trick. It's way easier to work with when it's warm.
The tape I use is high quality. I think it pactra brand, I get a big roll from my hobby shop. I think the main trick I've learned is to wear nitril gloves to keep from making snags and when I lay the tape I keep pressing it down firmly to make sure it's stuck firmly to the carbon. O and another important thing is to use sharp scissors, I use some .99 ones I get at harbor freight and I replace them often because they don't last long at all. I tried buying a $30 pair that's made for Kevlar but they didn't last much longer.....30 pairs of the cheapie will give me much more use for the same money. If your scissors aren't sharp and able to cut right through with ease then it'll pull the tape off and fray the fabric. When I put it in the hull and wet it out the tape stayed put, if it didn't you would really see it anyway because how far it goes up each side....it pretty much reaches the hatch lipOriginally posted by TheShaddix View PostReally great that you go into all that detail in your posts. I'm sure a lot of people appreciate that even if we don't mention it. There is always something new to learn! The inlay looks great. How do you keep that masking tape from separating when soaked? I tried this method but mine always came off and made a mess with carbon fraying, etc. Now I just use fabric glue, but the downside is that it takes time to cure. Oh, and keeping your epoxy by a heater is a neat trick. It's way easier to work with when it's warm.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
