It is a thing of beauty and a testament to your skill. You would regret it if you did sell it.
Project VooDoo mono build
I have some interesting news. I’ve been meaning to pull the logs and see what it says but I’ve had no time. Got around to it tonight. Well I found out I didn’t set the throttle end points correctly. I tried setting it like swordfish because that’s what I’m used to. Well an mgm is slightly different. Pulling my logs after I set the throttle and trying it out again on the bench (I tried it before and after on the bench to be sure before I made changes) confirmed it. I wish I would have thought of this when I was at the campground. O well, now I can’t wait to run it again to see what speeds I’ll get. I may end up running it on 6s also because that’s what I built it to run on. I can’t wait!32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
TravisOriginally posted by kfxguy View PostI have some interesting news. I’ve been meaning to pull the logs and see what it says but I’ve had no time. Got around to it tonight. Well I found out I didn’t set the throttle end points correctly. I tried setting it like swordfish because that’s what I’m used to. Well an mgm is slightly different. Pulling my logs after I set the throttle and trying it out again on the bench (I tried it before and after on the bench to be sure before I made changes) confirmed it. I wish I would have thought of this when I was at the campground. O well, now I can’t wait to run it again to see what speeds I’ll get. I may end up running it on 6s also because that’s what I built it to run on. I can’t wait!
I remember we talked about this a few years ago.
I was inquiring about the Castle ESC's at that time.
I remember the full throttle setting was 118% to 120%
This is what I use on all my Castle 240's
I have 8 of them now.
LarryPast NAMBA- P Mono -1 Mile Race Record holder
Yea that does work with some escs but I think it doesn’t help with an mgm. I just did the process wrong. I feel certain I’ll get the boat where I want it to be now. I think it should do over 50 on 4s and on 6s it should go really fast. At least 75-80 maybe more.Originally posted by TRUCKPULL View PostTravis
Larry32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
and each one that gets sold hurts a little.
