down the center works great for my pursuit. mines conventional, with the motor to the very back, batteries on a tray down the center.
Outboard pursuit
I am a little worried that the leads from the esc to the motor may be too long. I had to make them this long to rout the wires neatly and away from the steering/servo. what do you guys think??
Also these terminals come on the motor from factory, will they be good to use or should i use 5.5 connectors??
IMG_0530.JPGGO HARD OR GO HOME
How will I smoke the Hobbywing 180 ESC? Because of the connectors or the prop and motor combo?Originally posted by Beaux View PostThe connectors look a little lite if you have 5.5's I would change them. 6s is pretty hot. The prop you have should be ok.
If your running a hobbywing 180 6s will smoke it'GO HARD OR GO HOME
You are getting me worried, I run this same motor with a 120a seaking esc with a 2 blade 42mm prop 1.4 pitch with no dramas at all.Originally posted by Beaux View Post6s is 22+ volts and many mha's if you run 40mm or less prop it may last awhile, is your motor rated for such voltage . I have a similar size f1 hull with a 3650 leo 2200kv and 5s is way too crazy.
Capture.PNGGO HARD OR GO HOME
Just run it and chck the temps being its such a small boat you may have no problems, just check your temps.I've run mine on 5s in my mean machine approx. 4 mins. and it was pretty warm.
your specs say its ok so run it thats all I was worried about 6s is almost 40,000 rpm, it ought to fly , have fun is the main thing.
Just an update, pretty much everything is mounted in position, i also did a float test to check for leaks etc. No leaks and floats nicely.
Inside.jpgSide view.JPGGO HARD OR GO HOME
