Outboard pursuit
  • Outboard
    • Jan 2016
    • 50
    Outboard pursuit
    Hey guys/girls
    I have started building a FE O.S powered Pursuit boat.
    You can imagine i will be left with quite a bit of space inside the hull.
    What is everyone thoughts on mounting 2 battery packs down the centre of the hull instead of side by side/ conventional way?
    I thought better centre of gravity= better handling and less chance of flips etc
    thanks
    GO HARD OR GO HOME
  • boredom.is.me
    • Jun 2009
    • 626
    I think mounting them as low as possible should take priority over how wide the weight is disperced. From a physics standpoint, wider mounting should be more resistant to change, in this case rocking or chine walk, but tgat may potentially hurt maneuverability. Being realistic, the numbers are too small to actually matter.
      Lots of good information:
      Find information, resources and relevant links for modelpowerboat.com. This domain may be for sale.
      • Outboard
        • Jan 2016
        • 50
        Just thought about having them together standing up another option?
        GO HARD OR GO HOME
        • Beaux
          • Dec 2015
          • 550
          If it does'nt throw your cog off down the center is better.
            How did you decide to mount the OB? Is the prop center line above the keel or????
            I have the parts to do this, I just want to make sure I mount it in the right place the first time.
            • Outboard
              • Jan 2016
              • 50
              The prop shaft is in centre of the keel, with adjustment either way. Ill take come picture if you like.
              GO HARD OR GO HOME
                I understand. The pictures you already posted show it pretty well. Just needed to be sure.
                • Outboard
                  • Jan 2016
                  • 50
                  I am just at the point of starting to mount down the esc, battery trays and routing the wires as neatly as possble
                  GO HARD OR GO HOME
                  • Beaux
                    • Dec 2015
                    • 550
                    Very nice.
                    • Outboard
                      • Jan 2016
                      • 50
                      Originally posted by Beaux View Post
                      Very nice.
                      Thanks Beaux, its my first boat build
                      I need some help deciding on how to go about mounting the batteries. Should i place them flat away from each other like this
                      Or should i have them sitting against each other standing upright, this way will only require one battery mount and looks neater. I'm more worried how the hull will respond to either setup? Any help would be greatly appreciated
                      GO HARD OR GO HOME
                      • Beaux
                        • Dec 2015
                        • 550
                        Standing upright should be fine, and it does look neater.
                        • Beaux
                          • Dec 2015
                          • 550
                          Just be sure you have room to move them as far back as possible to adjust your center of gravity, should be approx. 30 %.
                          • Outboard
                            • Jan 2016
                            • 50
                            The way they are positioned now is at 30, those two marks in the last photo on the masking tape indicate 30% and 27%.
                            I'll bite the bullet and mount them this way, I just hope the hull doesn't want to roll over
                            GO HARD OR GO HOME
                            • Beaux
                              • Dec 2015
                              • 550
                              What size motor are you running. That boat looks good with an outboard.That's a good esc I'm running one in my DF Pirate.
