Revolt 30 rebuild
  • shua
    • Apr 2015
    • 479
    Just some final pics before the maiden.
    Setup is
    Castle 1512 2650kV motor
    Turnigy 120amp esc
    CapBank 4x1000uf 35V
    Hitec 5646WP
    Single 4s pack
    Added a few decals to make it unique
    • shua
      • Apr 2015
      • 479
      Revolt 30 rebuild
      And a comparison shot of both
      After maidens where complete and some dialing in performed, we saw speeds in the low 50s with excellent handling (this coming from a newbie mind you). I am pleased with them.
      Prop of choice so far is an X440.
      I plan to test more in the coming weeks.
      Temps were mostly acceptable. Running 4+minutes all out.
      The one area for improvement is with the capbank. It was getting hotter than I am comfortable with. I am planning to increase the size to 6 caps and shorten the esc and battery leads as much as I can and retest.
      And hopefully get some good video of them to share as well.
        Originally posted by TheShaddix View Post
        Really awesome work! Very nice attention to detail. One suggestion I want to throw in is to use some black dye for your jb weld so your joints look black and blend with the carbon. White stands out like a sore thumb in this case. You can still cover those up later too. Other than that, your work is very clean!
        Maybe it's the dye I'm using but every time I've tried to dye jb weld, the dye weakens it significantly and makes it more rubbery. I'm using a epoxy dye. I've had good results with graphite powder however.
        Nice work too!
        • shua
          • Apr 2015
          • 479
          Nice work too!
          Thanks!!!
          You know I think I do have a tube of graphite somewhere in my shop. I will give that a try.
          • Tamelesstgr
            • Jun 2014
            • 1512
            Wow, nice job, 50+ on 4s, how many watts is the castle rated for?
            NEVER SATISFIED RACING
            Fine Design 32 V-Hull 4082+6s
            • shua
              • Apr 2015
              • 479
              Revolt 30 rebuild
              Thanks! It's rated for 120amp. So That would be 1824 watts on 4s. I believe.....
              • bh_trade
                • May 2016
                • 16
                I've had success dyeing epoxy using a drop or 2 of black acrylic paint for a really small batch. Also have dyed JB plastic weld using same technique
