Revolt 30 rebuild
  • shua
    • Apr 2015
    • 479
    Revolt 30 rebuild
    A friend and I both bought revolts this spring. And after running in stock form we decided we wanted more...
    So after getting some great ideas and support from the members here, I dove into the rebuilds.
    First thing was to strip out the stock battery tray for a Carbon inlay.
    Scuffed it up well with 40 grit sand paper
  • shua
    • Apr 2015
    • 479
    On one of them I left the original motor mount in play.
    I painted the exposed FG areas to make it look cleaner.
    Dual Carbon battery trays were installed.
    Later we decided to add a center tray to allow for a single 4s pack to be used.
    • shua
      • Apr 2015
      • 479
      Revolt 30 rebuild
      First boat all buttoned up with a new Castle 1512 2650kV and a T120 esc with extra cap bank.
      Now on the second one I was inspired to go further. I removed the battery tray and motor mount and stuffing tube to do a more complete Carbon inlay.
      Stuffing tube was easily removed by heating it first using a soldering iron and then carefully twisting and pulling it out with a pair of pliers while still hot.
      • shua
        • Apr 2015
        • 479
        Revolt 30 rebuild
        And one piece inlay. Pretty happy with the turn out.
        I had one big mess on the Carbon behind the servo mount. In retrospect I should have removed the mount first. Next time.
        Fortunately it is not too visible.
        • shua
          • Apr 2015
          • 479
          Next comes a custom motor mount. It lowers the motor a few mm versus the stock mount and looks much better. Big shout out to KFXguy for hooking me up with the mount!
          I started to try to eyeball align mount and stuffing tube with just a piece of aluminum tubing in the brass to the motor shaft.
          I was advised to just use the motor collet and a piece of flex to get a perfect alignment. I made a temporary aluminum bushing to hold the flex in the center of the stuffing tub. Work very well!
          I tacked the mount in with JBQuick. And the stuffing tube with 30min epoxy and chopped glass
          • shua
            • Apr 2015
            • 479
            After it set, I removed motor and finished the JBQuick job in the motor mount side rails.
            Next I reinstalled motor with the same alignment technique to aid in the installation of my stuffing tube support.
            Checking alignment often I finally glued in the tube support with JBQuick as well.
            • shua
              • Apr 2015
              • 479
              Revolt 30 rebuild
              A single battery tray was used in this build. I trimmed the sides of the Carbon OSE tray to allow it to sit as low as possible.
              I shortened up the motor wires as much as possible too.
              Upgraded servo was installed and a little functional bling was added to the bow
              • bh_trade
                • May 2016
                • 16
                CF makes for a nice bling factor itself huh. Nice work!
                • shua
                  • Apr 2015
                  • 479
                  Very true. Thanks!!
                  • TheShaddix
                    • Sep 2013
                    • 759
                    Really awesome work! Very nice attention to detail. One suggestion I want to throw in is to use some black dye for your jb weld so your joints look black and blend with the carbon. White stands out like a sore thumb in this case. You can still cover those up later too. Other than that, your work is very clean!
                    • shua
                      • Apr 2015
                      • 479
                      Thank you for the kind words! The Dye is a great idea and would be a step saver too as I went back later with black paint and covered up the white epoxy to make it blend better. Thanks for the Tip!!
                      • TheShaddix
                        • Sep 2013
                        • 759
                        No problem, you can find it on ebay if you look for paint dye or epoxy dye. Painting the welds is not a good idea because the paint will flake off later. Don't put epoxy over that paint because it will just chip. It would need to be sanded down again.
                        • Tamelesstgr
                          • Jun 2014
                          • 1512
                          Nice job, I hope to learn how to do CF inlay this coming winter. What did you use, West Systems?
                          NEVER SATISFIED RACING
                          Fine Design 32 V-Hull 4082+6s
                          • shua
                            • Apr 2015
                            • 479
                            Thanks!!
                            I want to get a West Systems setup one day myself. But for this inlay I bought this kit.
                            https://www.ebay.com/itm/321694314441
                            It came highly recommend and I am happy with it as well.
                            • Tamelesstgr
                              • Jun 2014
                              • 1512
                              Well, that's an awesome find, thanks for the link.
