Delta Force 29 mono
    What motor did you get? Looks like a tenshock or an eBay motor not Leopard.
    • Mxkid261
      • Jun 2015
      • 734
      I believe it is a rebranded leopard because the box had a part number and then "-Leo" after the number, but I could be wrong. Its a 1400kv 4074 G-force from valuehobby.com. I have their 3674 in my hydro and for $36 it held up great this past summer, just needed some better bearings. This one was only $45 with the cooling jacket, so we'll see how it holds up Lol. Also I flipped the face plate and managed to drop the motor down about 4mm, which is as low as it will physically go. Gave me a little more of a gradual angle now. This is the motor Ray http://www.valuehobby.com/gforce-407...ed-1400kv.html
      • LarrysDrifter
        Big Booty Daddy
        • May 2010
        • 3416
        Lookin good!
        • Mxkid261
          • Jun 2015
          • 734
          Got the motor mount, battery tray, and ESC mount epoxied in. Just need to finish the steering and mount up some trim tabs/turn fins. Probably will be closer to when the ice melts that I finish it up. Still trying to decide if I should try a hatch bolt setup, they won't really sit flush on the hatch it looks like.
          • NativePaul
            Greased Weasel
            • 2770
            I would glue the insiders of the motor mount sides as well as the outsides, having double the glue area will make it's attachment much stronger.
            • StevenBryant
              • Nov 2012
              • 366
              I agree with Paul
              • Mxkid261
                • Jun 2015
                • 734
                I did end up doing the inside later in the night after I pulled the tape on the outside and after I took that picture. I never took the motor out when I did the outside after I had it tacked in, not sure why. Just wasn't thinking at the time clearly, might have been the coors lights haha.
