Delta Force 29 mono
  • Mxkid261
    • Jun 2015
    • 734
    Delta Force 29 mono
    Picked up a df 29 last week. Never put together a mono before so sorry if I have any dumb questions Lol. Got an inlay done over the weekend. Was going to use speedmaster 21 stinger and rudder. Anyone have any suggestions for powering it? Would a leopard 4074 2200kv and t-180 on 4s be an OK setup? Going to just be a sport boat. Any input is appreciated thanks. By the way any pointers on mounting the stinger Im not sure how to measure where the stuffing tube will go through the hull
  • Jesse J
    scale FE enthusiast
    • 7818
    Welcome to the build, there are extensive build threads at your disposal on this forum.
    You will have best success by doing some research on here and then asking specific questions.
    You will get advice from people who have little experience as well as those with lots, so be careful of faulty input. Follow Darin's race prep threads, for example. Also, If fluid ever chimes in, definitely listen to what he says, after all he DID write the book on FE boating! There are plenty of good ways you can go with this boat, have fun!
    "Look good doin' it"
    See the fleet
    • Mxkid261
      • Jun 2015
      • 734
      Finally got some stuff for this darn thing. Should get the hardware mounted and motor tacked in this week. Can't wait to try out the raider ESC.
        Start with hardware, the turn fins first since they are tightest.
        • Beaux
          • Dec 2015
          • 550
          That is a really good esc.
          • Mxkid261
            • Jun 2015
            • 734
            I didn't get fins yet but I will have room to install them after the stinger and rudder
            • boredom.is.me
              • Jun 2009
              • 626
              Hve you tried threaded backing plates? They eliminate the need for a fiddling with a bunch of nuts and also.eliminate the need for needing to use any tools inside of the hull which is great for tight spots.
              • Mxkid261
                • Jun 2015
                • 734
                I have threaded aluminum stock in a couple of my boats where spaces are very tight. There is plenty of room in this one but I'll still likely build a couple plates just for the added strength
                • Mxkid261
                  • Jun 2015
                  • 734
                  Finally got something done. Stinger and rudder mounted, stuffing tube in, and motor mount tacked in. Also cut some slots in a 2.5mm cf plate for a simple battery tray.
                    • 4340
                    Is it just me, or does the angle of the flex cable look a little steep between the end of the stuffing tube and motor collet?
                    • TRUCKPULL
                      • 3293
                      The front motor mount - The "V" is sticking up, it should be pointing down into the v of the hull.
                      This would also lower the motor down into the hull, - giving less bend leading into the stuffing tube.
                      Larry
                      • Mxkid261
                        • Jun 2015
                        • 734
                        Probably the angle of the picture, it is a pretty gradual bend. Flex spins nice and freely.
                          Larry is correct. To each his own.
                          • Mxkid261
                            • Jun 2015
                            • 734
                            Larry
                            Thanks. I will flip the face plate and see if I gain anything. The rear of the motor is about as low as it will go in the mount that is why I set it there.
                            • Mxkid261
                              • Jun 2015
                              • 734
                              Here is the angle right now. Don't mind the temporary blind nuts. I will try to get the motor lower like you suggested. Thanks Larry
