I'm fixing to build a df pirate you sure eliminated all of the guess work. Thanks.
Darin's DYMotorshop 33.5" P-Mono Build
Removed the motor/mounts and prepping to laminate in the carbon motor-mount plates. They are just CA'd in place at the moment.
Salvaged this aluminum servo mounting setup from a test boat, so I cleaned it up and will use it on this boat. I machined a lip around the perimeter of the base I fabbed for it, which should allow the layup to capture the base better.
Servo is one of the new Spektrum S6230 Digital Hi-Torque. 311 oz-in (22.4kg-cm) @ 6.0V. Should get the job done nicely. Yes... I believe is severe overkill for servos. Many a poor handling boat can be tracked down to inadequate steering control.
The Spektrum S6230 Standard Digital High Torque Metal Gear Surface Servo from Spektrum, the leader in spread spectrum radio control.
20160601_201747.jpgDarin E. Jordan - Renton, WA
Originally posted by Darin Jordan View PostRemoved the motor/mounts and prepping to laminate in the carbon motor-mount plates. They are just CA'd in place at the moment.
[ATTACH=CONFIG]143597[/ATTACH]
[ATTACH=CONFIG]143598[/ATTACH]
[ATTACH=CONFIG]143599[/ATTACH]
[ATTACH=CONFIG]143600[/ATTACH]
Darin that servo is now my go to on almost everything. Is badass. And that's an understatement. Waterproof and not power hungry. It reminds me of a radio post at 60% the cost of one. It has no slack and the ones I'm running don't seem to be gaining slack like all the blue savox servos I used to run. It's also a little more low profile than a regular servo. Anyone looking for a nice higher end quiet servo, this is the one you need.
I love those servo mounts too. I've been making a carbon bottom plate that replaces the original that the side pieces screw into. It makes for a better bond and because I'm not using a bottom plate like you are, it looks funny glueing it down with glue coming through the screw holes. Your solution looks nice too. I like the machined bottom plate and gives a lot of grab area for the epoxy.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I THINK, if it looks practical when I get in there to bond this all together, than I may laminate the bottom plate as well. If I'm careful, I think I can do a carbon layer that just captures those edges, without protruding up onto the servo plate.Originally posted by kfxguy View Post. I like the machined bottom plate and gives a lot of grab area for the epoxy.
Because of where I mounted the motor (way back), space is REALLY limited in there, so fitting this all in without creating a total hassle getting the motor in/out is going to be a tad bit of a challenge, but we'll get it!Darin E. Jordan - Renton, WA
That looks like the servo I'm needing for my TunnelOriginally posted by Darin Jordan View PostRemoved the motor/mounts and prepping to laminate in the carbon motor-mount plates. They are just CA'd in place at the moment.
Thanks for the link.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Working on getting the servo mounting system installed. Also preparing to laminate in the motor mount sides.
20160602_194225.jpgDarin E. Jordan - Renton, WA
Also prepping the motor mount to get laminated in place. Sides are just tacked in with CA at the moment.
This is carbon weave with a thin layer of glass veil glued to it. Sill all laminate up black when finished.
20160602_200528.jpgDarin E. Jordan - Renton, WA
Got the servo mount glued down and laminate layer of carbon fitted.
20160603_204045.jpgDarin E. Jordan - Renton, WA
Prepped the battery trays for installation this evening. They came (from OffshoreElectrics.com, of course) with only 4 base mounts. I wanted a little more security, so I fabbed some additional pieces and used them on the ends.
All parts were block sanded to scuff them up using 180 grit.
Once these setup, I'll block sand the bases lightly and install into the hull.
20160606_202735.jpgDarin E. Jordan - Renton, WA
Thanks...Originally posted by kfxguy View PostThis is looking good.
Yes. If you look closely above, you'll see that I pre-installed a carbon-twill covered in veil cloth (1.5oz fine-weave glass) along the sides of the motor mount plates and over the servo mount. I then wet them out to laminate it all in place.Originally posted by kfxguy View PostAre you putting carbon cloth over your epoxy (like around the motor mount?)
I wish I were a LITTLE more patient, because I think I could have installed the carbon a little more evenly, but honestly, it's NOT a show-boat... it's a race boat. I want it to be clean and hold together, so this should work fine.
I'm wondering if I might be overpowering this. I ordered a TP 4050 from OffshoreElectrics.com and it arrived yesterday. Freaking thing is a MONSTER! Glad I didn't follow my "more-more-more" twinge and order the 4060!
Here it is compared to the a sample Dynamite 4068 1750KV IM31 Motor...
20160606_195123.jpgDarin E. Jordan - Renton, WA
A 4050 is what I'd use for this size hull so I think your good
. I think the rtrs tend to have motors on the small size compared to what I like to have for some overhead. I like to have a little extra leeway. You'll be impressed with that motor if you haven't run one yet. They run quite well. I've slowing been swapping over to tp power here lately. And if you peel the rainbow sticker off the wire end on the motor, they are a very sexy looking motor.
Last edited by kfxguy; 06-07-2016, 11:21 AM.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
I ran my first one on my P-OPC Tunnel at the 2-Lap in March... 3640-sized... totally unprecedented performance that weekend. Brian B. experienced the same with his P-Hydro! Seem to be a great value motor!Originally posted by kfxguy View PostYou'll be impressed with that motor if you haven't run one yet. They run quite well.
I peeled off the sticker and placed it on the water jacket instead. (see picture above)Originally posted by kfxguy View PostAnd if you peel the rainbow sticker off the wire end on the motor, they are a very sexy looking motor.
Originally posted by Darin Jordan View PostI ran my first one on my P-OPC Tunnel at the 2-Lap in March... 3640-sized... totally unprecedented performance that weekend. Brian B. experienced the same with his P-Hydro! Seem to be a great value motor!
The latest iterations of tp motors are beasts. They are also building them better. 8mm shafts on the bigger motors. End caps screws on instead of glued.
The little 3650 I have (it's identical length and wattage to a 4050) is pushing my little 27" cat to 92 and I haven't even tried to go faster. It's too fast if there's a such thing but totally manageable and not violent. Very smooth motor which I'm sure is good for racing plus they don't seem to run hot. You'll be impressed with it.32" carbon rivercat single 4s 102mph, 27” mini Rivercat 92mph, kbb34 91mph, jessej micro cat(too fast) was
