37"Daytona:Bullitproof
    Well guys I've finally decided to get on with my first Dihedral design hull. So here is what I have:
    37" FC hull
    2 Trackstar 4074 2560kv motors
    110 stingers(to be shortened)
    MBP collets and 150 R&L cables
    A customized mini rudder from OSE
    Savox 'shorty' servo
    And a pair of SK 120 ESC's(which I am still undecided if adequate)
  • dmitry100
    • Mar 2015
    • 1264
    Since when did you get yourself some MBP Clicks on your Fantasm, shawn? :) How do you like them?
    Do they stand up to SAW ok? I heard they can sometimes move (left/right) etc after a crash...
      Those have been on there since I built it Dmitry. They have been great but mine are a little stiff to tune as I got a little loose with epoxy back there when I built it.
      • iridebikes247
        • 1669
        Looks like a fun build btw what cell count you thinking?
          Thinking 4s Mike but I have 5's as well, lol. Y'know, sport!
            5s is gonna haul. The 120's may do it but you might be cutting it close. We like overhead, just in case. Pair of seaking 180's would be ideal. I know you've got plenty of props to play with so it would be safer. This should be a very fast but budget build. Can't wait to see it done!
              I have a few Castle 200/240's here Travis, The garage sale air versions. I have been thinking of tuning a couple up for this. Once running maybe the 120's will be fine.
                As per my usual I installed a piece of 1 1/4"x 3/8" aluminum stock into the transom overhang. This I later drill and thread for the rudder standoff. I layed a piece of CF cloth across the transom section first then the aluminum and then another strip of CF wrapped right around the seam up to where my stingers mount.
                I also like to make stringer/deck braces for additional strength. I have found it really helps to stiffen it up and prevents the deck from collapsing if the boat takes a dive.
                • ls1fst98
                  • 905
                  Looks good as usual! Makes me want to finish my daytona I started like 3 years ago hahah
                    You were one of the reasons I bought one.
                      I got my stringers in, inlay and transom doublers in, and then drilled for my stingers and installed my motor mounts. All this done within a couple day window so all was mounted 'green'.
                        And here are the mounts setting up and after.
                        I am going with .150 flexes on this one so I installed a 3/16 flex thru the stinger and into a collett attached to the motor to maintain a good natural bend.
                          So this is my rudder which has been made from two OSE rudders. It is as close to 'scale' as I could come up with. I will most likely powder coat it later before final assembly.
                          Now for some thoughts from you guys perhaps; when I had these stingers on my Shocker I found they would get tweaked easily. So I have been thinking if I shorten them it would lessen the torsional side forces that tweaked them before. Does anyone know if the bushings just push through the tube wherever or is there a set ridge within? I seem to have up to 20mm or 5/8" to cut off of them
                            Looking good! I need some schooling on how to get my epoxy to lay correctly and not run. What epoxy are you using?
                            • iridebikes247
                              • 1669
                              I run the tfl stingers on my explorer I believe 108mm long. My boat was riding pretty wet so I cut off 18mm of stinger.
                              I ordered a bunch of bushings from OSE but after cutting it off I found I left the bushings intact, so just popped them out of the piece I cut off and pressed them into the drive tube. To answer your question I don't think they have a ring or at least the ones I cut down didn't, I cracked two drive posts from driving hard in choppy water since cutting down, much more durable.
                              The daytona will likely air out better with short drives
