Custom V cat
  • Shar75
    • Jun 2013
    • 17
    #31
    Cool! Elegant shape! And you're not going to make a copy of fiberglass? I would take myself so!
    • TheShaddix
      • Sep 2013
      • 759
      #32
      No fiberglass. If I ever make a copy, it'll be in carbon fiber, but this project is all about wood as my dad is making them.
        New version looks awesome! Making me want one!
        • Shar75
          • Jun 2013
          • 17
          #34
          If the agreement is ready to consider buying from you a copy of the body made of carbon fiber. If you do custom. The body is very beautiful! but the tree is not durable and plenty big. Sincerely, Alexander.
          • TheShaddix
            • Sep 2013
            • 759
            #35
            At this time I am not offering this boat in carbon fiber, but some day I might. However, until then, please, do not inquire about it as it is not the focus of this thread. And you're right, wood is not durable in its raw form as it's soft and cannot be exposed to water. But it is very durable and extremely strong if sealed in resin and can last forever. If you ever dealt with carbon fiber, you know the cloth has no strength or any value without resin. Once it has been infused with resin then it becomes that which we respect. Also, It takes layers upon layers to match the strength of even a thin wooden plank. I wasn't sure about wooden boats either at the beginning, but now I can see the beauty in it. This hull is build with really strong wood glue, then covered in resin during construction inside and out including the seams, and then I do another layer on top as a finishing step. Carbon and wood go hand in hand here. I still do a full cf inlay on the inside with 12k carbon, and then add expandable foam. The boat is also fairly light. We are constantly trying to shave off weight where we can. At first we did thick rib frames on the inside, then decided to remove them after the hull was completed, so now it's a frameless interior which reduced the weight. Also, the hatch is very thin and weights nearly nothing. The main weight is at the top deck due to it being a solid plank that's carved out, but we will work on removing as much weight as possible from it. As I mentioned, it is nearly as light as my fully built up mhz 114 mystic which has multiple inlays of carbon.
            • TheShaddix
              • Sep 2013
              • 759
              #36
              Here is the video!
              - 2x leopard 4082 1600kv motors with ceramic bearings
              - 6s turnigy heavy duty lipos,
              - octura 47mm props
              - turnigy 180A esc's
              https://www.youtube.com/watch?v=uZk7GA_vhtk
              • markwithak
                • Mar 2015
                • 38
                #37
                that's awesome
                  Runs good!
                  • Shar75
                    • Jun 2013
                    • 17
                    #39
                    Video - class!
                    And he'll paint you?
                    • Tamelesstgr
                      • Jun 2014
                      • 1512
                      #40
                      Those twins sound amazing
                      NEVER SATISFIED RACING
                      Fine Design 32 V-Hull 4082+6s
                      • TheShaddix
                        • Sep 2013
                        • 759
                        #41
                        Been working on this in the meantime. It's the latest vcat model.
                          Looking good!
                          • PowerDemon
                            • 353
                            #43
                            That looks great! The design really stands out. Fantastic looking boat.
                            37" Fightercat Shocker powered by Neu 1530 on 10S
                            • Tamelesstgr
                              • Jun 2014
                              • 1512
                              #44
                              Gets better each revision! You switching up the motor selection?
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2751
                                #45
                                This thing is beautiful! Incredible imagination and craftsmanship!
