MHZ 138 - McLaren Theme
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    Hello Folks,
    Time to do a new build. Some of the main features are:
    LMT 3040's with LMT couplers
    SF300 Lite
    MBP Click Drives
    Gundart cables and tubes
    Savos 1268MG
    A lot of custom carbon work. Here is an overlook of the 95% completed drawings
  • nata2run
    customcfparts.com
    • Nov 2011
    • 1876
    Here is the good part, I have spend some time coming up with a jig to fit the click drives. I have to say its one of the best things I ever did as it takes the guess work out of installing the drives. It also ensures that the drives are identical on both sides. This is very important for a potentional fast boat. Here is the process for installing the drives.
    • nata2run
      customcfparts.com
      • Nov 2011
      • 1876
      Ok, so the holes worked out well and the drives got installed successfully!!
      • nata2run
        customcfparts.com
        • Nov 2011
        • 1876
        Time to get the motors installed. The mounts are x2 3mm CF Plate to make a total of 6mm support. The McLaren tick was also cut into the plate. It worked out really well and I'm happy with the result.
        • Tamelesstgr
          • Jun 2014
          • 1512
          Awesome build, love the artwork ideas!
          NEVER SATISFIED RACING
          Fine Design 32 V-Hull 4082+6s
          • nata2run
            customcfparts.com
            • Nov 2011
            • 1876
            So far, so good. I got the mounts tacked in, and started to lay some glass strips around the mounts. I think I ended up with 6 layers on all sides of the mounts. This was followed by tinted epoxy with CF cuttings and some micro balloons (pics to follow) after that, I will do the final step and mask up again for a stream line look.
            • slr30ate
              • Apr 2015
              • 7
              Keen to follow this one, another piece of art in the making
              • RandyatBBY
                • 3944
                Hi Nate your work is always inspiring and clean. What graphic program do you work in?
                Randy
                BBY Racing
                • nata2run
                  customcfparts.com
                  • Nov 2011
                  • 1876
                  @sir30 thanks, hope it turns out nice
                  @Randy, I mainly work in Adobe illustrator, thanks for the compliments
                  • RandyatBBY
                    • 3944
                    It would be neet to see a thread on how you do it, and not hijack your thread.
                    Randy
                    BBY Racing
                    • nata2run
                      customcfparts.com
                      • Nov 2011
                      • 1876
                      Any parts in particular?
                      • nata2run
                        customcfparts.com
                        • Nov 2011
                        • 1876
                        Mounts are finally in!!! Should be nice and strong.
                        • iridebikes247
                          • 1669
                          Looks great Kent!
                          • Mxkid261
                            • Jun 2015
                            • 734
                            Man those drives are so sweet, exactly how much movement does each "click" provide? Cant wait to see this when its done!
                            • nata2run
                              customcfparts.com
                              • Nov 2011
                              • 1876
                              @ Mike, thanks dude!
                              @ MxKid, I believe 1 click = 1/10mm so 10 clicks should move 1mm
