Another Campell Shovel - part dew
  • egneg
    • 4759
    Originally posted by Sneasle View Post
    looking good.
    Where did you get the hull/kit?
    You can get it from the OSE store that sponsors this forum.
    IMPBA 20481S D-12
    • Sneasle
      • 202
      which one, the "Miss K' of the "shovelnose"?
      • egneg
        • 4759
        This one.
        http://www.offshoreelectrics.com/pro...Vintage-Shovel
        IMPBA 20481S D-12
        • studioRS
          • Jan 2009
          • 116
          This is EXACTLY what i want to build, please update with more photos, and any all hardware specs. Very kewl.
          What type of glue do you use for the wood to the ABS hull? 5-min epoxy? or?
          What type of glue do you use to bond the ABS hull top down with?
          Do you thin thin 5-min epoxy with rubbing alcohol to seal the wood parts?
          What rudder, strut set-up is that and prop? All available through the host OSE?
          Cheers, Thompson
          1/10 1954 Breathless U-22, Tahoe Yacht Club | 1/16 1958 Dumas Thiftway Too, built in '92
          • egneg
            • 4759
            Wow! - where to start?
            I used zap-a-gap ca to glue the wood to the hull.
            The deck is not glued to the hull yet but I plan on using 30 min epoxy. I have to first lay down the african mahogany veneer on the deck and part of the cowl. I have to paint portions of the cowl before the veneer goes down.
            I used a spar urethane to seal the wood.
            The rudder, strut assembly is the Solinger hydro system available at OSE along with the a .150 Hughey cable, teflon liner and 1/4 stuffing tube. The prop (Octura V940/3) in the pic will probably not be used but looked good. I will have to do some testing before I can give an answer to this. I also added the through the hull switch, water cooling bulkhead and outlet fittings, and scale driver all from here as well.
            The exhaust was made from ceramic pieces that I got at work (insulators from a thermacouple in a heat treat oven) and K&S brass tubing.
            If you have any more questions please feel free to ask.
            Chuck
            IMPBA 20481S D-12
            • egneg
              • 4759
              I pretty much have the cowl done - I wish I could take decent pictures.
              IMPBA 20481S D-12
              • Diegoboy
                • Mar 2007
                • 7443
                Very nice work on that cowl Egneg!
                • egneg
                  • 4759
                  I have the driver almost finished. I will spray it with a satin clear to take some of the shine away.
                  IMPBA 20481S D-12
                  • Flying Scotsman
                    Fast Electric Adict!
                    • Jun 2007
                    • 5195
                    Looks great Chuck and I like the idea of a satin clear finsh
                    Douggie
                    • egneg
                      • 4759
                      I have the deck epoxied to the hull and the lip removed. I used some polyflex to take care of any irregularities at the seam. Ready for primer, paint, and mahogany veneer on the deck.
                      IMPBA 20481S D-12
                      • egneg
                        • 4759
                        I finally have the mahogany veneer on the deck and the first coat of spar urethane.
                        IMPBA 20481S D-12
                        • egneg
                          • 4759
                          Final paint and clear is done.
                          IMPBA 20481S D-12
                          • Diegoboy
                            • Mar 2007
                            • 7443
                            It won't be long now Egneg. That'll look great on the water.
                            • GearHead
                              • 7
                              Thanks for the Inspiration...
                              EgNeg...
                              Thanks for the inspiration... Very nice looking build... My Classilc build is finally under way and your posts are going to be a big help...
                              I wonder which power system you plan to use ??? Steven has set me up with the AquaCraft UL-1 brushless combo... Should make it walk & talk !!!
                              Looking forward to hear how she does on the water...
                              Keep-em-Floating...
                              GearHead...
                              __________________________________________
                              Hammer / Hammer Modified / Crackerbox / Mini-Cat
                              Campbell Classic & Rigged Insanity - (In Progress)....
                              • egneg
                                • 4759
                                Thanks Diego - hopefully the weather will cooperate next weekend.
                                Gearhead - I am glad you like it and if I can help in any way just let me know. For power I am putting in an ammo 36/50/2300 and jeti/hacker 70 amp esc. I should have pictures in a day or so.
                                Speaking of pictures here is the cowl with the driver and exhaust pipes.
                                IMPBA 20481S D-12
