Another Campell Shovel - part dew
This is EXACTLY what i want to build, please update with more photos, and any all hardware specs. Very kewl.
What type of glue do you use for the wood to the ABS hull? 5-min epoxy? or?
What type of glue do you use to bond the ABS hull top down with?
Do you thin thin 5-min epoxy with rubbing alcohol to seal the wood parts?
What rudder, strut set-up is that and prop? All available through the host OSE?Cheers, Thompson
1/10 1954 Breathless U-22, Tahoe Yacht Club | 1/16 1958 Dumas Thiftway Too, built in '92
Wow! - where to start?
I used zap-a-gap ca to glue the wood to the hull.
The deck is not glued to the hull yet but I plan on using 30 min epoxy. I have to first lay down the african mahogany veneer on the deck and part of the cowl. I have to paint portions of the cowl before the veneer goes down.
I used a spar urethane to seal the wood.
The rudder, strut assembly is the Solinger hydro system available at OSE along with the a .150 Hughey cable, teflon liner and 1/4 stuffing tube. The prop (Octura V940/3) in the pic will probably not be used but looked good. I will have to do some testing before I can give an answer to this. I also added the through the hull switch, water cooling bulkhead and outlet fittings, and scale driver all from here as well.
The exhaust was made from ceramic pieces that I got at work (insulators from a thermacouple in a heat treat oven) and K&S brass tubing.
If you have any more questions please feel free to ask.
ChuckIMPBA 20481S D-12
I pretty much have the cowl done - I wish I could take decent pictures.IMPBA 20481S D-12
Very nice work on that cowl Egneg!"A quick temper will make a fool of you soon enough."
I have the driver almost finished. I will spray it with a satin clear to take some of the shine away.Attached FilesIMPBA 20481S D-12
I have the deck epoxied to the hull and the lip removed. I used some polyflex to take care of any irregularities at the seam. Ready for primer, paint, and mahogany veneer on the deck.Attached FilesLast edited by egneg; 03-01-2009, 09:15 AM.IMPBA 20481S D-12
I finally have the mahogany veneer on the deck and the first coat of spar urethane.Attached FilesIMPBA 20481S D-12
Final paint and clear is done.IMPBA 20481S D-12
It won't be long now Egneg. That'll look great on the water."A quick temper will make a fool of you soon enough."
Thanks for the Inspiration...
EgNeg...
Thanks for the inspiration... Very nice looking build... My Classilc build is finally under way and your posts are going to be a big help...
I wonder which power system you plan to use ??? Steven has set me up with the AquaCraft UL-1 brushless combo... Should make it walk & talk !!!
Looking forward to hear how she does on the water...
Keep-em-Floating...
GearHead...__________________________________________
Hammer / Hammer Modified / Crackerbox / Mini-Cat
Campbell Classic & Rigged Insanity - (In Progress)....
Thanks Diego - hopefully the weather will cooperate next weekend.
Gearhead - I am glad you like it and if I can help in any way just let me know. For power I am putting in an ammo 36/50/2300 and jeti/hacker 70 amp esc. I should have pictures in a day or so.
Speaking of pictures here is the cowl with the driver and exhaust pipes.Attached FilesIMPBA 20481S D-12
