Rearwheelins Rumdog Re Do Rico 31" HD Speed Version
    They look SOOO good, I don't know which motor to use yet, I wanted a CC 1717, but was told that will be too big. I was adviced to use a Neu 1527, but I have not looked at the hull for so long and it's been stored at my Mom's.
    Will the standard one come with a roll of holes on the side plate for epoxy grabbing?
    • rearwheelin
      • 2101
      #32
      It will ! It will have all the holes as the original and will probably look even better. I haven't completed the side plate template fully yet but adding holes to it is the next step.
      I'm pretty darn excited about this mount !
      --Albert Einstein
      • rearwheelin
        • 2101
        #33
        My short $150 56mm TP motor is rated at 4500 watts continuous and 8400 watts peak. This mount will have no troubles with that . The mount is 2" tall and I can drop the bolt patterns lower should you want a single pattern and a long motor so you can get better clearance .
        --Albert Einstein
        • rearwheelin
          • 2101
          #34
          The one on the bottom has one extra epoxy hole than the original on top. I got crazy with the holes on the production cut out trying to figure out the production pattern but it was a fail ! lol the original is a much more optimal approach lol I will make a duplicate of the holly one pm me if anyone is in interested in it . These epoxy holes will be in the final design.
          --Albert Einstein
          • rearwheelin
            • 2101
            #35
            --Albert Einstein
            • Luck as a Constant
              Make Total Destroy
              • Mar 2014
              • 1952
              #36
              Nice dude!
              • rearwheelin
                • 2101
                #37
                Originally posted by Luck as a Constant View Post
                Nice dude!
                You just let me know when you need one Luck I'm going to give you a nice discount ! Just PM me when your ready.
                --Albert Einstein
                  Originally posted by rearwheelin View Post
                  This is the updated side plate. It's what they will look like.[ATTACH=CONFIG]131146[/ATTACH]
                  Awesome, I will let you know as well.
                  • rearwheelin
                    • 2101
                    #39
                    I have a low pro mount I designed for a 1527 to fit in a H&M Intruder . I kept my spec sheet on it . This was my original one. So I got you covered if this new one is too big. I will probably make these ones again too, but aluminum :)
                    --Albert Einstein
                    • rearwheelin
                      • 2101
                      #40
                      11 hp 31" Rico
                      --Albert Einstein
                        11 hp 31" Rico
                        [ATTACH=CONFIG]131158[/ATTACH]
                        Yup!
                        • Spartanator
                          • 1060
                          #42
                          I can do a rear support but I would get the Chinese one from kintec more than likely . These mounts are strong enough to run with no support if the motor can is up to the task. If you you like send me a long motor and I can see how I would go about making the rear support . I may need to modify the side plates a little for a rear support. I would advise a rear support on the real long motors although I have run 1527's with no support and no issues after crashes although I have seen pics of what can happen with no support .
                          PM me your address so I can get the 4092 sent out!
                          • rearwheelin
                            • 2101
                            #43
                            Thanks ! PM sent ! I think peoples hang up with the mount is no rear support so this is a good opportunity to implement one !
                            --Albert Einstein
                            • Spartanator
                              • 1060
                              #44
                              No problem!
                              I do to, this is my opinion: I believe some like the CF because it does have some give IF they have a real bad crash and it looks nice. The mount could be painted or even wrapped (maybe a HyrdoDip would work too) so it could match the paint. Maybe we could work a trade (plus $) on that 4092 for the 1717.....
                              • rearwheelin
                                • 2101
                                #45
                                Are you looking for a indestructible layout ? Then Rearwheelins "SAW Boat Shenanigans" drop in unit might be for you ! LMAO ! This thing should keep you on the lake unless you break your boat in half !
                                It's still a work in progress .....
                                --Albert Einstein
