Rearwheelins Rumdog Re Do Rico 31" HD Speed Version
  • rearwheelin
    • 1941
    --Albert Einstein
    • rearwheelin
      • 1941
      --Albert Einstein
      • rearwheelin
        • 1941
        --Albert Einstein
        • rearwheelin
          • 1941
          --Albert Einstein
          • rearwheelin
            • 1941
            --Albert Einstein
            • Luck as a Constant
              Make Total Destroy
              • Mar 2014
              • 1952
              Jb putty I see
              • rearwheelin
                • 1941
                Originally posted by Luck as a Constant View Post
                Jb putty I see
                It's QuickSteel but I'm sure they are close.
                --Albert Einstein
                • rearwheelin
                  • 1941
                  --Albert Einstein
                  • rearwheelin
                    • 1941
                    --Albert Einstein
                    • flraptor07
                      • Aug 2013
                      • 2451
                      Originally posted by rearwheelin View Post
                      [ATTACH=CONFIG]130986[/ATTACH] [ATTACH=CONFIG]130987[/ATTACH] [ATTACH=CONFIG]130989[/ATTACH]
                      Mount looks real nice! I think Dave @ HRC does the 1717 mount too, I don't see it on his site but I'm almost positive he does one.
                      • rearwheelin
                        • 1941
                        Thank you !
                        --Albert Einstein
                          • 5660
                          Been too busy this past week, couldn't keep up with you, looks great. Them motor mounts are lovely. I see how easy it is to take the motor out with the front plate. Also is this boat going to have a wet tube, the transom center hole is rather large...
                          • rearwheelin
                            • 1941
                            It will have a wet tube for the extended strut I'm putting on it . It may be a little bit before I get too far into the build . I kind of need to earn more boat money lol
                            I'm working on perfecting the mount JIC others may want one hint hint
                            --Albert Einstein
                              • 5660
                              If I ever get to my ML 400 build.......
                              • rearwheelin
                                • 1941
                                On the left is a TP5650 mounted to the first 3 production components templated from the original and has the motor plate in hydro form , these parts will interchange with each other and be duplicated the same. It also can bolt up standard 25mm and 6 bolt 30-35mm . The universal bolt pattern is extra time and $$ . Pic your one pattern or spend more and bolt them all up ! Ok I'm dreaming again lol
                                --Albert Einstein
