cooling tube ferrules/ hull trim rings for hose
  • ECSURFER84
    • Jun 2013
    • 91
    4mm is the I.D. with a 2mm wall would be 8mm O.D. 1/4" = 6.35mm
    Ok more importantly, will 4mm hosing fit my stock equipment? is 4mm a standard interior dia for most fittings? or would i need hose clamps?
    • Heath M
      • Mar 2008
      • 806
      Try it and see, if it feels a bit loose put a cable tie around it to tighten againts the fitting.
      Brisbane,QLD, Aussie
      • flraptor07
        • Aug 2013
        • 2451
        You can use 4mm on most fittings but I use clamps on some fittings that feel a little loose just to be safe. These are the ones I use, you can get them @ Kintec. http://www.ebay.com/itm/like/3312414...lpid=82&chn=ps
