DF pirate 35 build
  • Luck as a Constant
    Make Total Destroy
    • Mar 2014
    • 1952
    #136
    35" boat needs a 1527 1.5D 1500kv on 6s would be perfect!
    That's what jay said.
    Others tell me1527 is way to much.
    I'm confused lol
      • 6057
      #137
      I'm confused lol
      That all depends on what you want. If you want something just to absolutely max out the hull speedwise just get the biggest motor you can cram in it. If you want a sound, maneuverable boat that is still fast you can use a 4074, 4082, 1717 or 1521 etc.............. These FE boats already have absurd power to weight ratios. Its like having a 2000 hp engine in a Camaro and saying yeah but I would like 2500!
      Folks run 1527's in 1/8 hydros(45+ inches).......yep tons of vids on youtube
      I run a 4082 in the 45" Scarab in my avatar, runs just like I want it to, nudges 40mph on 6s2p.
      Don't get me wrong, too much power is not a problem, sometimes its just overkill that's all..............just get what YOU want and you will be happy
        Make Total Destroy
        • Mar 2014
        • 1952
        #138
        I guess worst case is I just upgrade if I had to.
        A 1521 has gotta be enough.
        • flraptor07
          • Aug 2013
          • 2451
          #139
          True, but it depends on kv a 1527 1.5D 1500kv on 6s in that boat will give him a 60-65mph boat. Does that mean you have to run it WFO all the time, no it doesn't but you can if you want.. I'd rather have a little more power than I need than not have enough and get bored with it real fast. You can always prop it down to get a certain max speed if you want to run it WFO.
            Make Total Destroy
            • Mar 2014
            • 1952
            #140
            you both make great points
              Make Total Destroy
              • Mar 2014
              • 1952
              #141
              I mounted the stinger up 5mm. Should be enough
              • flraptor07
                • Aug 2013
                • 2451
                #142
                That should be fine, BTW it's lookin' great! My TFL Ariane is a 36" hull and very simular to the Pirate the 1527 setup is what I run in it for Q-Mono that's how I know about how your Pirate is gonna perform. What kv is your 1521?
                  Make Total Destroy
                  • Mar 2014
                  • 1952
                  #143
                  thanks man.
                  i haven't bought a motor yet actually. the 1521 comes in a 1577kv option...
                    • 6057
                    #144
                    Yep it's looking great, tabs look to be mounted perfectly.
                    BTW, I am not pushin for any certain motor, I am just pointing out both sides.
                    Once again..............what do you plan to do? Sanction race..............Saw..................WOT around.......................sport, that's the bottom line as far as which motor to get.
                    • flraptor07
                      • Aug 2013
                      • 2451
                      #145
                      Agreed... depends on what you want out of the boat.
                      • flraptor07
                        • Aug 2013
                        • 2451
                        #146
                        Nite Nite guys....
                        • rearwheelin
                          • 2101
                          #147
                          Whatever you get run it wide open .
                          --Albert Einstein
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            #148
                            DF pirate 35 build
                            Thanks everyone for your input. Yesway
                            I am sport running.
                            Would like good run times and hoping to get around 60
                            Cheers gents
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #149
                              Luck, do you need me to text Jeff for you?
                              i got a pm from jeff today, with an invoice in paypal and some decals going out this week.
                              should add the finishing touch
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #150
                                DF pirate 35 build
                                Tonight I got back to work on the cf inlay.
                                I went ahead and layed a big piece under the deck. All I have left is too lay strips down the seems.
                                Today I got a nice pic of it on frozen water
