DF pirate 35 build
    • 5554
    #46
    Originally posted by Luck as a Constant View Post
    Yeah I see what you mean.
    As far as power goes tho, which has more?
    I'm gonna say the 1717, 5mm more diameter and a hair longer too. As i said it pushes my 39" mono to 60.
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      #47
      I should post some pics.
      Used wax paper to make a templet on the cf
      And test fit
      I'll be doing two layers
      • flraptor07
        • Aug 2013
        • 2451
        #48
        Much better lookin than the regular DF 35, Do you know if they are the same bottom?
          Make Total Destroy
          • Mar 2014
          • 1952
          #49
          I'm not sure on that...
            • 5660
            #50
            Agreed, love the free board. Regular DF35 has ride pad, no?
            Inlay template looks good!
              Make Total Destroy
              • Mar 2014
              • 1952
              #51
              No idea on that.
              The only thing I can say it that there is a very small difference in length and width of them. So small I would be inclined to say that it's only because the top decks are different.
              However, looking at pictures of the two, the pirate looks a bit deeper V, but it's impossible to tell from just a picture
                • 5554
                #52
                The Pirate is a bit taller and deeper vee. Looks awesome
                • flraptor07
                  • Aug 2013
                  • 2451
                  #53
                  From studying the pics, I'm pretty sure the bottoms are the same. The Pirate looks deeper because of the little extra freeboard and that's what makes the difference in the length and width.
                  • TheShaddix
                    • Sep 2013
                    • 759
                    #54
                    That inlay looks great! What grit do you use to sand the hull down prior to laying in the cf? Also, since you're doing 2 layers, have you thought of just getting 6k cloth instead? Just a suggestion as that'll save you time and it's easier to work with.
                      Make Total Destroy
                      • Mar 2014
                      • 1952
                      #55
                      I used 180
                      No I hadn't thought about heavier cloth. I just got some good easy to use cloth. I'll consider that in the future thanks!
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        #56
                        If you want to do a nice job, it's necessary to have the rite materials.
                        A bit costly, but worth it.
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          #57
                          DF pirate 35 build
                          Guys, if you aren't using west systems 105, I highly recommend it. I've used zpoxy for years and never has it been this easy and good looking....
                          • Rocstar
                            Joel Mertz
                            • 1509
                            #58
                              Make Total Destroy
                              • Mar 2014
                              • 1952
                              #59
                              Keith kinda guilted me into it lol
                              But I'm super happy I did... It's the small things that make it next level.
                              I really like the 105/207 also, because it's crystal clear. No yellow whatsoever
                              • Rocstar
                                Joel Mertz
                                • 1509
                                #60
                                It's all I use....Really makes a difference.
