Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 DF pirate 35 build - RcBoaters Forum
DF pirate 35 build
  • jbracehabits
    • Jan 2013
    • 84
    #391
    Any suggestions for motor mount for the 1717 castle?
    • Luck as a Constant
      Make Total Destroy
      • Mar 2014
      • 1952
      #392
      Talk to member on here Rearwheelin. I think he was making some nice ones.
      Also I believe fightercat has some
      • jbracehabits
        • Jan 2013
        • 84
        #393
        Thanks luck, really appreciate the responses.
        • jbracehabits
          • Jan 2013
          • 84
          #394
          So I ordered the ose.187 assembled cable for 3/16" props,
          1/4" brass tubing, mono stinger, cf cloth, some lil things, and heading to pick up west systems 105/207 right now.... Boat should be here Monday!
          • jbracehabits
            • Jan 2013
            • 84
            #395
            What size turn fins did you use? Or recommend? Also your trims tabs? I think the speed master billet CNBC aluminum tabs are awesome. Looks like that's what you used as well correct? Thanks man
              Make Total Destroy
              • Mar 2014
              • 1952
              #396
              Yes those are the trim tabs indeed.
              http://www.offshoreelectrics.com/pro...d=ros-spdt-502
              The turn fins are the large
              http://www.offshoreelectrics.com/pro...prod=ose-80066
                This excellent build thread must be way above 10,000 view count were it not for the non-updating-status of the view counter. ()
                • jbracehabits
                  • Jan 2013
                  • 84
                  #398
                  Hull should be here any time! Anybody run the neu 1527? Can't decide between that and the castle 1717... Any input thanks!
                    Make Total Destroy
                    • Mar 2014
                    • 1952
                    #399
                    DF pirate 35 build
                    The 1521 was plenty for this hull. A 1527 would be complete overkill. In fact the 1521 barely knew it has run. It really only got warm after s full run.
                    If you want to overpower it, the1717 is s great budget friendly choice. The 1527 is just more money, and pretty much not needed at all
                    • jbracehabits
                      • Jan 2013
                      • 84
                      #400
                      Ok good to know, I was gonna spend the more money thinking higher price=higher quality. Did you ever get close to 60 like you were hoping, with the 1521?
                      • jbracehabits
                        • Jan 2013
                        • 84
                        #401
                        Hull showed up! Was frightened when I saw the box damaged, but it's all good! Made it to Cali unscathed. Cf should be here any day, along with some hardware... Ordering motor and motor mount tomorrow.... Let's get this mother going! Still waiting for the sf 240 to be in stock, might look into other options if it's too long of a wait. Pumped though!
                          Make Total Destroy
                          • Mar 2014
                          • 1952
                          #402
                          DF pirate 35 build
                          You know, I never gps it, but I'm pretty sure on the 448 I was hitting 60. I actually propped down to a 445 for sport running
                          The nue motor is def worth the money, but when it comes to 1521 or 1527, the 1521 was more than enough to send it airborn. Plenty of power
                            Make Total Destroy
                            • Mar 2014
                            • 1952
                            #403
                            I used a sf 220 esc.
                            Start a build thread brosef. Be happy to see what you do man.
                            I have some extra amg logos if you want them. Dunno what you had planned
                            • jbracehabits
                              • Jan 2013
                              • 84
                              #404
                              You bet, thank you for all your help, and your thread lit a fire under my %$&! I'll start a new thread too. Going to buy a new air brush this week, some thing simple and classy like yours I hope. Thanks again
                                Make Total Destroy
                                • Mar 2014
                                • 1952
                                #405
                                No prob man!
