8255 Build
HAHA Ray, did you ever pick that one up? It's creepy light. At the close of our practice season I put a 1527/.5y in it. Fastest thing I have ever driven. One stuff and I'll be calling a diver though. Not a real setup but the grin factor was high.
I'll take a pic later but after sanding the poly foam down on that curvature it looks pretty good. I'll have to glass it but it doesn't look as horrible as I had anticipated. I'll show how I backed the foam too. Pretty simple.Noisy person
Okay first pic is from the inside looking forward. I basically closed it off with ply. Then poured foam on the outside. Cured then shaped.
Second pic is just from the outside after some sanding.
20150217_183031.jpgNoisy person
Epoxy and two layers of what ever scrap I found in my shop. Think it's 1.5oz S glass.
20150217_213307.jpgNoisy person
I'm the last one to tell you how to do something and it looks awsome. While you were there I think I might have incorperated a air brake in the nose like on the ML boats. You could always fill it in if it wasn't needed.
I just can't do it.
Building around a design flaw just doesn't set well with me. I'll keeping massaging the setup until it works without an air dam.
I don't like adding 13oz of weight to my Stealth either. I'll be fixing that bugger before I paint it too.Noisy person
Cool, I was more or less asking, you deffinetly have way more experiance with rc boats than I do. That's basicly the answer I was looking for. ThanxOriginally posted by T.S.Davis View PostI just can't do it.
Your PTSS? for LSH? holly crap, 13 oz's! I added 3 to front of port sponson and it doesn't sponson walk anymore. Of course I'm carrying heavy 7.6AH on board too and an esc like an anchor... We'll see with soft water. I first have to find my leak. Taking my PTSS to the GF's place on the weekend since she has a tub to test in...Originally posted by T.S.Davis View Post
Yep, pretty much the same. I can get away with cheap packs that weigh a ton but, your lead is even less $$$, lol...
I'm switching to the Hacker packs I bought from Jason so, I might need to add weight or just work on it more like yourself. PM me all your hard work and secrets
Originally posted by T.S.Davis View PostStupid ain't it Ray?
I only carry 4400 mah though so we're doing the same thing. You're extra 3200mah and chunk o' speedo might weigh another 10oz.
haha I didn't say I had it figured completely out. We have a bunch of these in MI. They all have a hair trigger. You're right at the ragged edge and........................................ then you take flight. weeeeeeee It's why your heavy packs work.
After I figure it out I'll tell you exactly what to do. Want me to drive it for ya too?
Noisy person
