Problem Child scale hydro
  • RandyatBBY
    • 3943
    #31
    Looking great Mick. Running a CNC must be fun!
    Randy
    BBY Racing
    • mickieb49
      • 256
      #32
      Thanks Wayne,
      Randy it certainly makes things a lot easier mate, I can be sure everything is true and straight , then it is also easier than hand shaping ( even though I stil enjoy that part too), and when it comes to scaling it up or down, that's quite simple.
      Machining the sponsons today, so stay tuned.
      Cheers Mick
      • Shooter
        Team Mojo
        • Jun 2009
        • 2751
        #33
        Very nice. What end mills did you use? Did you run a rough cut first, and then a finish cut with a ball mill?
        • mickieb49
          • 256
          #34
          r/h sponson machined, now will put the steps on them.
          shooter i use ball nose bits for all, better at plunge cuts too..
          • Shooter
            Team Mojo
            • Jun 2009
            • 2751
            #35
            Looks good. 1/2" or 1/4" ball end mill???
            • mickieb49
              • 256
              #36
              5/8" for the roughing, 1/4" for the finish.
              • drwayne
                • 3012
                #37
                Waiting for the tub to arrive ... so I can start fitting in the needed go fast equipment.
                Sponsons a month later would be fine.
                ( hint hint ) LOL
                • mickieb49
                  • 256
                  #38
                  Working as fast as I can Wayne, not easy working full time, having 2 small kids under 4, a wife with 2 businesses....... LOL. Aint life fun!
                  I am about to put skim coat of bog over the plugs, then got to wait for it to dry then it's sanding time.....
                  Regards Mick
                  • drwayne
                    • 3012
                    #39
                    • Shooter
                      Team Mojo
                      • Jun 2009
                      • 2751
                      #40
                      Mickie, sorry for all the questions, but I'm going to try to cut a cowl on the shopbot this weekend. I have my finishing tool path setup for 10% step over. Do you think that is too small? I'm also planning to run 2 in/s feed at 12k rpm with a 1/4" ball mill. MDF material. Any direction would be helpful. Thanks.
                      • mickieb49
                        • 256
                        #41
                        Shooter,
                        The questions are fine mate. depends on the required finish mate, but i have about a 0.125" stepover on a 0.25" bit, find i still need a little bit of hand sanding but mu chachine also isnt running for like 2 days straight.... With the feed rate, i run 110" /min feed rate, at 18000rpm, much faster and you will start breaking the bits. I bought some longer series bits from alibaba, they are 6" long for a 1/4, and 350mm (14") with a 5/8" but those are only for foam. Hope that answers your question
                        • mickieb49
                          • 256
                          #42
                          Just a little project update- This project is now in the hands of DRwayne.
                          Im sure it is in good hands, and hope he will update this thread as it all happens.
                          • drwayne
                            • 3012
                            #43
                            Waiting for courier with the boxes !
                              • Shooter
                                Team Mojo
                                • Jun 2009
                                • 2751
                                #45
                                Originally posted by mickieb49 View Post
                                Shooter,
                                Thank you. This helps out a lot. Only thing missing is the depth of cut per pass? How deep do you cut?
                                Pete
