I doubt it, I used a 30 amp iron and was very careful, I did notice some corrosion around the TX lead on it. I plan to order a new one soon, along with some lipos.
Yes, another Catamaran Build!
I felt the floor was still too weak (1/64 ply and 1 layer light fiberglass) so I added a layer of carbon fiber cloth. The epoxy set up quicker then I would have liked, so it has some thicker spots then I wanted. I am thinking about mixing up some finishing epoxy and spreading it around so it all looks uniform, I like to keep it minimal with epoxy because I like the fiber texture, but too late for that, I should have used 30 min epoxy not 15 min. It still looks pretty good though.
More updates pretty soon, the hardware will be going on very soon, and batteries will be ordered soon as well as a LVC, and I really need a new reciver because the ones I have are just too big, I'm thinking spektrum 3500, but am concerned about range. I would like to try the new spekturm marine reciever, but that means I need a new radio.
Twin power =
Well That looks nice after you get all you r gear inside it will look just like you bought it that way.Peter Eells; Fun, and Helping others To Have Fun!!!
http://rcboatsbypetere.blogspot.com/
RC.Boats.by.Pete@gmail.com
I have been using one of those cheap tactic 2.4ghz, pistelgrip ones in two of my boats and never have had aproblem yet, only 79.99 and the rx is small and has an internel antanna so no wire, very easy to remove and place in another boat or just get another rx and bind it to the same tx...
Here I am installing magnents to help hold the hatch on, which will be nice when you are trying to tuck the wires down inside. Plus it will help keep the hatch from warping. It fit perfect till we painted it, then it warped it, so my plan is to warp it back, (which I already did) then apply fiberglass to the underside, and then put it in place while the fiberglass dries, which should help keep it where its suppose to be. Well anyways, there is more work to be done on this magnent install, this is just a start.
Currently the finish resin I put on the floor is drying, it really did make it look better since the epoxy set up too quick when I was installing the carbon. The floor should not flex now.
Carefully drilled a hole, carefull not to go through to the nice paint on the other side
Here is the magnent glued in, I didn't want to drill any farther so the magnent sticks up just a tad as you can see, but thats no big deal.
These are neodymium magnents, 1/8 diameter. They are very strong.Twin power =
Ok, here is where I installed a peice of 1/8 to make space to put the magnents on the hull its self.
Here is where I resanded and sprayed the bottom because it had some funny spots in the paint because I didn't sand the epoxy/resin good enough before paint. The bottom will be wetsanded and recoated then I will 1200 and 2000 sand the whole boat and hand buff it out. Soon I will be installing all the hardware and electronics, hopefully my replacement esc will come in soon. I am going to be doing a few more finishing touches to the boat.
Twin power =
Man thats nice, but i thought it was better for the under side to be rough,less dense, less drag in the water.
You are right, but if you saw what I sanded off you would understand. I wont polish the bottom out. I just need to get one more nice coat on. I used krylon rattle cans for the bottom, sort of stinks because the rest of the boat is super high quality auto paint (House of Kolor red, PPG black, PPG clear) I can't wait for this stuff to dry, hope it gets hard because the last time I used rattle cans the paint never really got very hard. Worst to worst, I will convince my wife that I need a airbrush and detail gun and a compressor and do it the right way
then clear it and then rough it with some 600 sand paper.
I'm anxious to get the electronics laid out again. I need to buy some batteries still. I'm looking for some that are high mah, but aren't too big that I cant make any fore and aft adjustments.
Here is my MAX availble battery space
H=33mm
W=75mm
L=110mm
So if anyone recomends any 3 cell lipos that fit within those measurements LMK, the hobby king ones are looking pretty good.Twin power =
Those are the ones I use and they just fit and I mean just, I was considering making the hull 1/8" wider in the plans just for that reasonPeter Eells; Fun, and Helping others To Have Fun!!!
Oh by the way use the 2000 grit on the clear coat as the thickness may not be too thick and you do not want any burn throughs, they really blow trust me, too bad that dremell dosen't make a larger pad for buffingPeter Eells; Fun, and Helping others To Have Fun!!!
Dust blown out and protective tape removed. Don't worry, all exposed wood will be painted, just finishing up all the little details. Hopefully tomorrow I can wetsand the bottom and recoat and finish up my servo mount and touch up the exposed wood parts you see.
Twin power =
ok nail it down looking great your father would be proudPeter Eells; Fun, and Helping others To Have Fun!!!
