Carbon fiber single daytona build
    replied
    Originally posted by Chris Nason View Post
    That is one sexy boat ...when ya going to get it wet?
    I'm not so sure yet. I will post as soon as I do tho. Thanks!
    Leave a comment:
  • olwarbirds
    replied
    I totally cover my capbanks in a plastidip too, no probs..looks good Trav...that temp gauge would be a nice tool for getting setups right, instead of having to check logger constantly... DJ
    Leave a comment:
  • Chris Nason
    replied
    Leave a comment:
    replied
    Travis did you completely plasti did your cap bank ? just got mine done wasn't sure if I should dip the whole bank or just the bottom
    I usually do the whole thing. I think i covered this one mostly too.
    Leave a comment:
  • Chris Nason
    replied
    Got some done last night. Mainly worked on the cheetah. I put the 2 part foam up front and finished wiring up the esc then I powered it up and programmed it. Basically I'm waiting on my through hull water fitting fit the water line. I have a couple odds and ends left but I'll probably have most done this evening. Check out this ugly contraption..... I guess it dont matter what it looks like as look as it does the job and it will be covered anyways. Funny still.
    Leave a comment:
    replied
    Originally posted by Fella1340 View Post
    Great job Travis. I need you to get yourself up to Canada and crank out a few boats for me! Looking forward to see how It handles for you and how fast you can make it go.
    I'm charging batteries for it tomorrow. Today was absolutely beautiful and perfect. No wind. About 70 degrees. I couldn't get out there because we had a family dinner to attend. I was gonna try for 100 with the rivercat. Hopefully tomorrow is as perfect. There is a pond behind my house.... it was like glass with no ripples. I missed out. Got my collet today. I'm making the flex right now and fishing little odds and ends.
    Leave a comment:
  • Fella1340
    replied
    Leave a comment:
    replied
    Originally posted by PowerDemon View Post
    Oh ok. I dident realize that it went through the transom the way that it does. I thought you had installed a fitting on it like you had done on mine.
    I changed the way I'm doing it on tight transoms. I get so aggravated with getting the hose on and putting a zip tie on that I've almost thrown a boat against the wall. So to keep my sanity and my stress level down, this is my solution. I'll still use the bulkhead fitting on easy to reach transoms.
    Leave a comment:
  • PowerDemon
    replied
    Leave a comment:
    replied
    Beautiful.. You should look into getting some of KBBs braiding water cooling hose. It really adds to the look. Just a thought. Did you reshape the rudder to decrease overall thickness?
    Thanks. I'm pretty happy with the way it's turned out so far. I have some of that Hose and while it's nice, it wont work for me. The hose goes directly through a fitting in the transom and the soft or rubbery texture is what seals it. The rudder I didn't make thinner, just sharpened and made it a straight edge from the sharp edge to the rear of it. Was worth a solid 1mph with my other boat in back to back testing.
    Leave a comment:
  • PowerDemon
    replied
    Leave a comment:
    replied
    And for comparison this is my rivercat with the same two 4s packs complete.
    Leave a comment:
    replied
    Well I guessed at the beginning it would be around 9lbs ready to go. Well I was pretty dang close....
    Here it is empty.
    Here it is with two 3s packs.
    And here is is with two 4s packs....
    It was weighed complete. Flex in it. And canopy on it.
    Leave a comment:
    replied
    Little update. Got the rudder reshaped and sharpened. I also drill the break away hole bigger and rethread it for a bigger nylon screw. I learned my lesson with my rivercat is why I do that.
    Got the steering completed. It all hooked up and operational. Everything seems to work fine. I think my collet will be here tomorrow, I'm not making the shaft or stuffing until it gets here.
    Steering hooked up.
    Leave a comment:
    replied
    What is on the cooling can then? Where is the temp gauge? I was looking forward to seeing that. I love how you have hidden the water lines and the wires. Beautiful build..
    Thanks! That's really think carbon fiber sheet with 3m adhesive on three back. There is a seam at the bottom and it's epoxied together. I'm on the fence about the gauge. I cannot flush mount it. The screen and circuit board is seperate and have to to be lined up perfectly to connect. I'm going to explore some other options.
    Leave a comment:
