36 inch scrach mono build!!!!!!
  • lonewolf
    • Jul 2007
    • 713
    In theory the leading edge of the rudder should be around the same as the leading edge of the prop or behind the prop somewhere in that range.
    • rcboatfan
      • 253
      okay thanks lonewolf. i still havent got those darn ribs cut out
      SUPERVEE 27 37'' TWIN CAT
      • rcboatfan
        • 253
        what speeds do think i will get with a 8xl on 2x2s lipos in series with a octura 646 prop
        • rcboatfan
          • 253
          anyone
          • lonewolf
            • Jul 2007
            • 713
            What kind of 8xl kb or feigao???? I feigao may not hold up a 9xl would be a better choice for a feigao and strart with a 440 and work your way up.
            If a kb 45 8xl I would start with a 440 also and work up...Starting with a 442 might be ok... Speeds depend alot on which motor and how you get it trimmed out...
            • rcboatfan
              • 253
              i was thinking feigao. but i think i finally decided on a motor.........................kb 45 9 xl. i finished my rudder and mount like ten minuts ago im just painting it now.ill start posting some pics tommorow if i get somthing set up with photo bucket tonight
              • lonewolf
                • Jul 2007
                • 713
                pics are easy to post directly to here...
                • rcboatfan
                  • 253
                  really i dont need photo bucket?!! because on the traxxas fourm i did
                  • lonewolf
                    • Jul 2007
                    • 713
                    nope click on the lil paper clip at the top and a attachments manager will open and aloow you to post up to 5 pics...If they are really big you may need to reduce the size
                    • rcboatfan
                      • 253
                      o sweet thanks lonewolf
                      • rcboatfan
                        • 253
                        ill start with sime pics of just the rudder because my mount that i made is being painted shuold be finished by tommorow.
                        • rcboatfan
                          • 253
                          so what do you guys think
                          • lonewolf
                            • Jul 2007
                            • 713
                            nice looking but... unless I am seeing it wrong the pivot pin should be on the leading edge of the rudder not the trailing edge... If it is on the trailing edge the force of the water will flip it aroung or try to and possibly strip out the servo...
                            midway back would be the farthest recomended... Hope i made sense...
                            • rcboatfan
                              • 253
                              dang i knew i did that i will drill a new hole tommorow. thanks for the info (im new to the hobby this is my first rudder ill post a pick of the mount tommorow see if i did that right)
                              • rcboatfan
                                • 253
                                would this be a better position??
