36 inch scrach mono build!!!!!!
  • rcboatfan
    • 253
    hey guys,im building a 36 inch mono from plans from lonewolf.im thinking of getting the peices lazer cut.i do not know what setup to get. i want to stay with nimh batts and i want to get between 35 to 40 mph or faster if possible i think im going to make all my own hardware. im so excited
    SUPERVEE 27 37'' TWIN CAT
  • rcboatfan
    • 253
    i have 1 more question. does the prop exit the boat staight or does it have to be on an angle.
    • lonewolf
      • Jul 2007
      • 713
      Angle left or right normally no some saw set ups might do it??
      But straight out with adjustment for angle up and down.
      • rcboatfan
        • 253
        could i use a strait shaft instead of a flex shaft
        • lonewolf
          • Jul 2007
          • 713
          A straight shaft would not be advised. You will not be able to adjust the trim angle
          • rcboatfan
            • 253
            what set up do you think would be good to get 35 to 40 mph on nimh
            • lonewolf
              • Jul 2007
              • 713
              how is your budget...
              • lonewolf
                • Jul 2007
                • 713
                Check out my 37 in mono build. There is a good place to start
                • rcboatfan
                  • 253
                  i dont really have a buget
                  • rcboatfan
                    • 253
                    what turn would i get with the kb45
                    • lonewolf
                      • Jul 2007
                      • 713
                      If you can afford it I would go with a Neu motor and lipos, best investment.
                      As far as the kb I am useing a 8xl but a 9xl will work also...
                      I would suggest doing some research of the build threads and see what others are useing for their set ups....
                      The best way to learn this hobby is read read read. And use the searh bar at the topof the page....
                      There are many possible set ups for a 36 in mono. It is hard to pick just one that works.
                      Then there is budget. Many think scratch building is the cheap way to go, it is not by far the cheapest way. If this is your 1st boat I would do alot more research before going much farther...
                      A 36 in mono can cost a few hundred to well over a thousand. Do you have all the support equip chargers cells ect. If not there is several hunfred more to spend.... This is a grea hobby but it is NOT a cheap one, it can be done on a budget but not without alot of reading....
                      Dave
                      • rcboatfan
                        • 253
                        this is my first build but i have been into rc trucks for two years now so i have all the batterys and chargers. i just wanted to stay with nimh because i just bought 120$ charger that only does nimh but lipo might be pretty wild after all this is a winter build and there is christmas :)
                        • lonewolf
                          • Jul 2007
                          • 713
                          I would do some research on hull building, there is alot to be done and if not done correctly it will show up later in the build. You may also want to do some mods specific to your tastes or set up.. Getting the g/c correct is important and is best figured out in the early stages so that you can adjust for it later in the build...
                          Read up on sealing the wood and the use of fiberglass if you are not versed in it and plan on useing in your build.
                          Read up on the various types of epoxies and their uses. Some are better than others.
                          • rcboatfan
                            • 253
                            i need new batterys for my e maxx so i might get some lipos
                            • rcboatfan
                              • 253
                              im just building a rudder and i am wondering how much setback it should have
